Results 1 to 10 of 54
Thread: Budget 4ac Mods
    Senior Member Water Boy's Avatar
    Default Budget 4ac Mods
    Copied a list of ideas from the old forum.
    I know the 4ac is a pretty basic and low powered engine but for many it is the start for many hill sessions
    Get someone to cut a new slot in the cam gear so that its held in a 5 degrees advanced position. This for me made me lose about 0.5 to 1L to 100km however I had a reasonable power gain between 3000 and 4000rpm.
    Other than that a free flowing carb will probably be the best bang for buck
    Advance the timing, run 98, flip the air filter lid upside down and bolt it on again, 2 inch exhaust with at least one baffled muffler.
    replace the plugs, dizzy cap and rotor button.
    Thats all thats really worth doing.
    Head shave for some more compression, cam, carb, valve springs.
    weber carby, straight through (or close to it) exhaust, 98 ron fuel, timing advanced all the way, remove clutch fan fit thermo.
    also a button clutch makes those clutch kicks more potent.
    elec dizzy, good plugs/leads, timing advance and 98
    small exhaust, weber if youre rich
    Hope that helps some newwer people to the Toyota side of things like myself! But as have most said if you are really keen save some extra dollars and go straigh for the 4age conversion.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    one I did: get an additional slot cut in the cam gear so it hold the cam in a 5 degrees advanced position. There will be a power gain beween 3000 and 4000 revs
    Veteran slide86's Avatar
    Huw
    Hills
    lid flip FTW
    Senior Member Dylan's Avatar
    Dylan
    one of these
    what about something like this
    http://www.toyotapowered.com/index.php?showtopic=6
    Veteran shift_rook's Avatar
    SE Burbs
    itb's on a 4ac seems like a bit of a waste to me
    Last edited by shift_rook; 12th January 2009 at 07:25 PM. Reason: it said 4age but yeah i dunno how i muddled that up
    Davey & Riki-lee
    South Australia
    Seaford SA
    on a 4ac i hope you mean
    Quote Originally Posted by Dylan View Post
    one of these
    Change to mint elec dizzy with better plug-cables, put in one of those ^^, change to a better muffler and ur good to go with better mid-range response n fuel consumption.. havent tried better plugs tho..
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Interesting to note that some 4ACs are better than others, depending on how they have been treated, etc. Eg. mine seems to run better with 95 at the moment, with 98 it seems to flood the motor, its a lot more peppy with it.
    Also, pulling the snorkel out from the intake is a useful quick fix. Keeping it well serviced is also an important thing to do
    Member Aezion's Avatar
    Seb
    my carby on the 4ac is dead, all it does is want to stall. my mate had this laying around said it would run alot better then the carby.
Name:	Copy of Jodies Cam Pic 030.jpg
    hopfully get it on this week i got a couple days off
    Seb
    32/36 downdraft and redline filter.
    [IMG] [/IMG]
  1. Replies: 1
    Last Post: 5th July 2012, 04:14 PM
  2. [MELB] AE71 spirit 4ac with mods+rego
    By Jdm070 in forum Cars for Sale (Toyota Only)
    Last Post: 10th September 2009, 07:21 PM
  3. Wanted - - - 4AC harmonic Balancer urgently (mods please dont delete)
    By 20v ae71 in forum Adelaide & SA Events and Discussion
    Last Post: 1st June 2009, 12:51 AM
  4. Budget '09
    By PuGZoR in forum Offtopic Discussions
    Last Post: 12th May 2009, 07:22 PM
  5. Budget Upgrade
    By ke70_sa in forum Technical - Questions
    Last Post: 12th April 2008, 06:08 PM
