huh?15 by 8 with 0 offset will fit just bash the square lip flat so it dosent slice up your tyres and use 195 50 15 tyres,15 by 9 will need a bit of pull 15 by 9 is a big wheel on a ke
What things do i need to squeeze in the 15x8's in my ke70?
These are 15x8, idk the offset.
Will they?
jack your car up and see ,i duno, hope they do and look sweet,bit risky buying shit not knowing the details
Just measure the wheel, then take your wheel off the car, put some bricks under the LCA so it's at ride height, measure distance from hub mounting face to guard flare, and compare to wheel specs worked out, done.
If its a 15 x 8 , they look around a zero offset,
If not , it won't require much guard work to make them
Fit.
8 up front and 9 on rear is nice IMO
Ps those achillies atr's need to be pumped up hard, sidewalls are very flimsy! Even when stretched
as said, 15x8 -+ 0 is easy, lip guards. Done
They look like the China steelies that I am seeing alot these days.... They are 15x8 0 offset...
Thats an example pic. Lol
probably will get tires that can handle small stretch and fit with the stock struts
yeah just thought id let you know... i tried them at my last track day, you can feel the sidewall flex under you, and when compared to my re001's ( when both not fitted ) its apples and oranges... could have made the achillies side walls out of a good orange jelly... would have been just as affective, just tasty
