I moved the brake line outta the way and drilled from the inside out.. I moved the rubber outta the way and marked the firewall from the inside with a texta. Don't panic if you get it slightly off as the clutch master will cover it up.
I used a holesaw for the clutch slave hole and made it slightly larger with a die grinder.
Nothing wrong asking q's if you share what you learn with others
