Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 10 of 91
Thread: Mclevin's 86 bi@#*es!
    Veteran McLEVIN's Avatar
    Nov 2010
    Default Mclevin's 86 bi@#*es!
    Well finally getting around to a build thread after owning my 84 Zenki ae86 for 2yrs now.
    It's an import but basically the same as ADM in all honesty.
    I was a noob when I first bought it and paid way too much for what it was, but I was impatient and wanted a imported one. Was looking at a couple Tim.Duncan's old silver gze, and a later panda Levin.
    In retrospect I should've opted for timmy d's but was not keen on a few minor things and being inexperienced I wanted a N/A car.
    (any one know of this car and its whereabouts?)
    When first aquired
    Shortley after
    Then I drove into a fence whilst being a Dick. Damage is not bad but dented the Rad support and chassis support.
    I covered up the damage with a new bumper (zip tied on as one mount was bent)and removed the bonnet latch to put in bonnet pins so the bent bonnet would sit more flush.
    Couple of months later I got a major defect
    -too much play in seats
    -modfied suspension
    -steering wheel
    -low tread on tires
    * note cop didn't look twice at the damage
    So it wasn't going to pass with the damage so stripped it. And has sat dormant in my shed for the past 9 or more months
    MOPAR or no car!
    Nov 2010
    The specs I should prob mention.
    It came with, from what I can remember/can see, are
    Driveline
    Bigport motor+t50
    264 hks Cams
    Apexi safcII
    Custom 2inch exhaust + extractors ceramic coated (mild steel)...sold
    Jun BL muffler and 2.5 twin pipes...still have
    Zenki drum t series with trd 2way LSD.
    Wheels
    6.5 xr4s front 20mm spacers
    7.5 xr4s unknown offsets
    Suspension
    Cusco strut brace
    Cusco Canberra tops
    Trd blues front and rear
    Trd springs Unsure of kg
    Cusco rcas
    Anyone know?
    6kg front 4kg rear i assume felt really good for street very firm ride but still enough play.
    Stock sway bars I think.
    Cusco adj panhard rod
    Interior
    Red GTV seats
    150mm dildo shifter
    New sparco suede 350mm thanks to autosport (best wheel)
    Ajpsdash mat.
    New plush carpet.
    That's about it
    MOPAR or no car!
    Nov 2010
    When stripping it found some rust which I'm not happy about (i know its to be expected) but I'm not really sure if its bad or normal
    The engine is coming out over the weekend so fairly soon I'm gonna have to bite the bullet and make my mind up on what I'm going to do with it.
    Restore it to something I can get registered but as a track oriented car...so pour big $$$ into.
    Dump the parts into it that I've bought and track it.
    Or find a registered JDM shell.
    So far the parts I have are
    7age.
    full stainless Janspeed exhaust system.
    Pair of Velo GP90s will have to get it regod as a 2 seater.
    ...the joys of living in SA. Not!!!
    MOPAR or no car!
  • #4
    Nov 2010
    Here is the new heart, courtesy of pen15.
    7a block .5mm oversize
    7a crank stock size
    king half groove main bearings (brand new)
    king bigend bearings (brand new) spool con rods
    wiseco pistons comp ratio is 12.37-1
    7a stock brand new Toyota genuine oil pump
    7a sump
    4age 16v stock head gasket
    Toyota genuine 4age 16v bigport head ported to the shit
    288deg toda cam shafts at 8.5mm lift in and ex
    toda single valvesprings fidanzaadjustable cam gears Porsche timing belt
    t3 quad throttlebody adapters ae101 silvertop individual throttle body's
    Noby Booth carbon intake
    stock 2nd hand head bolts stock 2nd hand main cap bolts
    arp 2000 rod bolts (comes stock with spool) and just Toyota genuine seal throughout
    exedy 4 puk brass button clutch rwd alternator bracket & alternator rwd engine mounts
    rwd water setup
    t3 underdrive waterpump pully engine loom
    Exhaust
    MOPAR or no car!
  • #5
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    So,working bee this Saturday still on Chris? Been out of phone reception.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  • #6
    Marco
    Btw,this will be evil with a good tune and e85 with the comp and cams
  • #7
    Nov 2010
    Yeah man just me, svenmate, and another friend, feel free to come by.
    MOPAR or no car!
  • #8
    ACT
    Compton
    Good to see ya getting stuck in chris! Where did ya pick up the janspeed? Ya should maybe get different exatractors though, the janspeed ones aren't supposed to be great.. You'll love the sound!
  • #9
    Nov 2010
    I got roadrunner to send it from the UK.
    I'll play with extractors later, I got just for the sound. Haha.
    MOPAR or no car!
  • #10
    Marco
    Good progress made today. Turning spanner's amongst a good group of car nuts. Looking forward to the finished product.
  • Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
    1. buying a lens/es
      By ae71 in forum Photography & Digital Design
      Last Post: 29th January 2010, 04:23 PM
    2. Bi-Tron engine oil additive
      By sundee in forum Technical - Questions
      Last Post: 3rd April 2009, 03:29 PM
