Results 1 to 10 of 14
Thread: 16v small port high idle
    Senior Member KAYE70's Avatar
    Apr 2012
    aidan
    nsw
    kellyville
    Default 16v small port high idle
    Hey all. My mate has a ae86 with small port 4age.
    Both of us are pretty new to these motors. I have a carby set up. But on his efi one it has a problem of high idle. And im talking 2500 rpm all the time
    Everynow and then it will idle around 2100 rpm and sometimes hunts between 1000-2000rpm.
    Idle screw is wound all the way down from previous owner. So technically speaking it shouldnt idle? Or if so would be almost dying.
    Any ideas on what out problem is? Throttle back stop is not to far adjusted.
    Ive been told idle control vaulve. Is there a way to fix it if that is the cause or just replace?
    Apr 2010
    Mike
    vacume leak, smoke machene, or spray carby cleaner/brake cleaner around the intanke mani, until you here a exhaust note difference
    Veteran Nikkojoe's Avatar
    Tom
    I always ask this when people ask about this problem, but have the water lines been set up to the throttle body? if not it means your cold start idle up will always be open. If it hasn't been connected, unbolt the cold start idle up under the throttle body and either plate it off or place a piece of thick gasket paper to block it.
    Also this has been posted many times, search next time
    Apr 2010
    Mike
    thought that was RWD bigport mani's???
    Apr 2012
    aidan
    nsw
    kellyville
    Dont think its a leak. Have tried wat you said no luck there
    Apr 2012
    aidan
    nsw
    kellyville
    Okay will try that tomorrow.
    Thanks for your help.
    And yeah sorry i dont get on here much to have time to search stuff lately. Been heaps busy so was a quick post
    Veteran timbo's Avatar
    Tim?
    Wild West
    1- Take off intake pipe at throttle body.
    2- Find the bigger of two holes on the bottom of the throttle body.
    3- Place finger over bigger hole.
    4- If you feel suction your idle will drop and you know that the cold start idle up is flogged.
    5- Win.
    I think this should be put somewhere for future reference. As nikkojoe said it has come up quite often and seems to be a reoccurring problem for 4AGE's, especially smallports (I have the same issue with my SP).
    Tom
    I think it's more people being miss informed when converting a fwd to rwd or being slack and not doing it right(as in not connecting the same way as factory). I think some people believe that when you remove certain aspects of the setup it will all work the same...
    Tim?
    Wild West
    Haha true, very true.
    Apr 2012
    aidan
    nsw
    kellyville
    Yep its flogged. Thanks for your help
  1. 16v Small Port Parts.
    By Zane k in forum Cars or Parts Wanted
    Last Post: 18th November 2012, 10:52 PM
  2. High Comp small port pistons with ae111 head on 7a block?
    By Grant #2 in forum Technical - Questions
    Last Post: 5th May 2012, 11:12 AM
  3. WA 16v small port
    By racermotors in forum Car Parts For Sale
    Last Post: 31st May 2011, 11:37 PM
  4. small port and big port heads, 256 cam,16v rwd water stuff
    By dehney in forum Car Parts For Sale
    Last Post: 17th December 2009, 05:24 PM
  5. 16v Small port VS Ae111. Rwd
    By AE86R in forum Technical - Questions
    Last Post: 4th April 2009, 03:52 PM
