SR crossmember is almost straight bolt in. Elongate 2 of the holes and Bazinga. Bolt sr into ae/ ke
Seen a few people selling them in the states does anyone know of people selling them here?
would be interested to see where it positions the LCA, could get around the camber issues by using s12 or 31 LCA
Thanks for the tips lads, bolting the sr crossmember in would that require much cutting of the trans tunnel?
Call Tasmanian mobile mechanics on 0362734777..
They have a jig designed for ae86 and ae71 crossmemeber..quite a few cars running said setup reliably
MY AE86 BUILD
Slight bashing of the tunnel is required as far as I know
Or modified mounts....
So fit an SR in PROPERLY requires enlarging the tunnel. More than can be done with a hammer..
^^ negative. Get a bigger hammer
Hahahahaha.
