Results 1 to 10 of 11
Thread: F series diff axle removal
    Senior Member AE86 Spoontah's Avatar
    Brendon
    Ellenbrook
    Default F series diff axle removal
    Hi all,
    I'm trying to pull the centre out of my F series diff but i can't seem to get the axles out. There are no circlips holding them in at the hub ends so i'm a bit confused. All i can see on the end of each axle is a bearing but surely that's not all that's holding them in, am i wrong?
    Cheers, Brendon
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    Only thing I can think of is to flip the drum around and bolt it back on and pull it as hard as yyou can (without pulling it off the stands
    Just another Muppet
    Jake
    Northgate
    Should just be 4 bolts holding axle bearing housing to diff housing, and yeah if you dont have a slide hammer you can do as above and bolt your drum on backwards. Then might need a bit of effort breaking the seal on the center but other than that shouldnt take longer than an hour to replace the center (providing no problems like above though, haha.)
    Brendon
    Ellenbrook
    It's a full custom setup with ally brackets behind bearing housing for twin rear calipers, so no drum brake . So all i need to do is press it off using bolts or just keep pulling on it till it comes out.
    Gunner
    Put a wheel back on loosely and use it instead.of the drum
    Vaughn
    Sunshine Coast
    Gunner knows
    Just another Muppet
    Gunner
    Gunner blew 6 diffs over january lol
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Good way to break a drum.
    Wheel on and hit the wheel with a hammer, obviously steelies not 15x9s
    West
    I like to bolt a chain to the wheel studs and use a sledge hammer or heavy steel bar to slide hammer it out. Well that was before I bought a slide hammer anyhow.
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Even if you've got the most basic of welding skills and some scrap steel you can just make a slide hammer. I long steel tube, get a sledge hammer n flatten the end, then put in a vice and curl it into a hook. The just weld up a base plate and sliding weight. Mines about 6ft long cause some axles can be super shit to get out.
  1. T series diff/rear axle wanted
    By terryo in forum Cars or Parts Wanted
    Last Post: 3rd July 2011, 08:44 PM
  2. T series Diff, Good condition. Or R/h Axle.
    By Dish in forum Cars or Parts Wanted
    Last Post: 26th April 2009, 08:19 PM
  3. WTB S-series axle/diff
    By jamekins in forum Cars or Parts Wanted
    Last Post: 20th March 2009, 02:06 PM
  4. S series diff/axle
    By loc33e in forum Technical - Questions
    Last Post: 17th January 2008, 05:17 PM
  5. T 18 SERIES 1 DIFF AXLE!
    By drif86s in forum Cars or Parts Wanted
    Last Post: 20th October 2007, 04:39 PM
