The float could have a very very small crack in it filling the float up with fuel which weighs the float down leaving the needle on wide open throttle causing the bowl to overflow so take the carby off and check the float, and if its been sitting around cor 4 years you best off pulling the carby apart as it probably has old old fuel that turns into a jelly substance blocking some jets tiny ports
