There's a place northside Brisbane ( w w shocks ) I think, I will confirm the name and post a Ph number for ya tomorrow
I have some front and rear trd greens and want to know if there buggered the fronts dont rebound at all is this right? They just use the spring for rebound? And the rears when on number 1 its like the valve is opened heaps and it rebounds real fast and on 8 (highest/stiffest) it takes like a min to fully rebound after full compression? This seem right? Also non of them are leaking can i get them tested at fulcrum or somwhere to see if there still good?
Many thanks David
W w shock absorbers 07 3265 2133
talk to these guys, they can rebuild the shocks too ; )
True
Ok thanks Jamie i did figure out they were hydaulic when i compresed them by hand but the rears did extend by them selfs on setting 8 it took like a min and on setting no 1 it took abot 10 seconds to fully extend back. just the fonts dont extend/ rebound at all but thanks thats all i needed to know
Also is there a website that looks into all this? Like are trd greens (soft) best for higher or lower spring rates etc?
TRD greens are fucking hard man, they're best run with something 6kg/mm +
Best comparison I can give is a TRD Blue adjustable (front) on it's 2nd hardest setting, greens are the poor mans blue.
