Pm sent.....
all this kit is up for sale.
all enquiries welcome.
i will need to get some good pics, but ill pu up what i have now.
i have a few pics in the build thread here --- >
NOTE - All parts listed here are quite literally brand new, been driven on 2 track days and some laps around the street ( car was never registered)
here we go: the following shell can come with any of the parts listed below as they are all still in the car.
Ke70 Bare shell. ( not rolling )
2 tone 2K paint work, gunmetal with black roof
matt black bonnet
very straight,
flared guards front and rear
Engine bay still in factory paint
interior stripped and painted matt black
headlining still in roof
cluster and dash top supplied
rear seat supplied
Pimpin Fluro tube interior light
comes with spare guards for front on rear conversion
some minor rust just under fuel door and in the lower rear sill. but that is all.
Has rear wiring harness, which has been re wired at the drivers kick panel
all lights were wired up to the centre switch panel i made up.. so the factory loom is gone and re wired to suit my centre switch panel.
No fuse box etc. so if you want it factory, you will need the factory harness etc.
Tuff looking shell.
SOLD!
One off Custom Hypertune Front Rad support - supports rad and ae86 headlights.
10 times stiffer then factory support ( just a reference )
$420 ( pictured below )
Exhaust System - 2 1/2" - 2 x hotdog resinators - Twin 3" drift rear pipes
Under diff, can be mated to a dump/front pipe or NA headers
$680
Diff :
MK 2 Corona F seires 4.3:1
TRD 2 way LSD
Mounts modded to suit 86.
Custom Traction brackets
Same track as ae86/70 etc
VERY RARE!
No breaks, ( guys have been known to buy whole cars just for this diff )
$1950 Firm (deposit taken)
3" custom Single Piece Tailshaft - Suit W box to F series Diff.
$440 (deposit taken)
Coilovers and brakes
front: suit ae86, ke70, ae71 etc
Based on ST141 struts ( i think, has same KPI as 86, spent a few hrs at pick n pay less with a digital angle gauge)
KYB AGX 4 way adj shocks
200mm 8kg springs with helper
R33 gtst 4 pot callipers
300mm DBA vented/ X slot rotors
custom hi tensile alignment ring
QFM A1RM's pads
T3 camber plates
T3 upper hat system
New Koyo wheel bearings
All parts are basically brand new - driven on a few times, done 1 track day.
epic setup - fit under 15" superlites
$2100
Please see Suspension for PS steering arms and RCA's to fit this setup onto anything running a BJ145 balljoint.
AE71 pedal box - SOLD!
AE71 clutch master, AE86 slave with Speedflow 200 series teflon braid, stainless speedflow fittings - $200
BM44 nissan non abs brake master with custom adjustable stainless pushrod
custom plate for booster removal
with Speedflow 200 series braid line to front brakes thru to rear splitter
with wilwood screw type bias valve mounted in cabin
$700
Rear Brakes
SD Garage Twin Calliper setup
296mm DBA Vented Rotor, converted to 4 stud
4 x R33 GTST twin pot calipers
SD garage Custom alloy calliper bracket, CNC machined from 2024 grade aircraft alloy ( one of a kind )
all grade 8.8 hardware
all stainless fine tuning alignment shims
- 4 braided teflon line, speedflow 200 series fittings throughout.
QFM A1RM in all 4 callipers
$1550 (deposit taken)
Hydro hand brake with wilwood master - suit above setup - $130
Suspension - all parts are literally unused
Front:
T3 AE86 Rose Jointed Adj LCA - $390 ( SOLD )
T3 AE86 Rose Jointed Castor rods - $200 ( SOLD )
T3 33mm RCA - with grade 8.8 hardware (suit above coilover setup) - $95
Custom T3 AE - MX Extra lock PS Knuckles - (Suit above coilover setup) W/ T3 Rose Jointed Outer tie rods - $239
Selbys 24mm Blade adjustable swaybar with electroplated mounts and urethane bushes - $220
Rear:
TRD Blue 8 way adj shocks (used), good condition, no leaks - SOLD
AJPS AE86 adj spring perches, 120mm free height springs (perch adds another 80mm) so full height is equivalent to 200mm springs, 6kg/mm, Great adjustability, at full heights it sits nice with the ability to slam it hard if desired. - SOLD
Selbys 20mm blade adjustable sway bar with electroplated mounts and urethane bushes - $220
T3 AE86 rose jointed panhard - SOLD
T3 AE86 Rose Jointed 4 link ( un equal ) - $380
Fuel System
JDM AE86 EFI fuel tank with Walbro 500hp in tank pump - SOLD
Aeromotive EFI billet ally fuel filter - anodised red 120 micron ( will confirm that ) - $130
Speedflow 100 series braid
-8 feed and - 6 return ( 11mm & 9mm )
setup for 20valve in ke70, will suit ae86 aswell
all that would be required is adapters to attach the female hose ends to your engine
at the tank end the braid is adapted to barbed push on fittings.
this system can easily be used with a surge tank, but is setup to be used with the main tank only.
$400
Random
AE86 engine x member - great for replacing your bent one or dropping a 4a into a ke70 - $120
Cusco 4a engine mounts - 12mm lower - as new ( comes with factory heat shields) - SOLD
ae86 Custom W box gearbox x member - SOLD
Twin cam steering wheel - good condition - $150
Exhaust 2 1/4" with muffler and 3" rear pipe - suit KE70 or ae71
$330
Custom made center panel
6 x autogauge 60mm blackout gauges
oil temp
oil press
water temp
boost
A/F
EGT
12 switches and push start
$495
Bride Vios III seats x 2 - SOLD
ae86 Buddy club super low down seat rails
( can make them sit a 70 ( drivers rail already is in a 70 )
drivers and passenger - SOLD
Willians 4 point harness - blue $250
Located in sydney near camden
contact - PM or post
serious buyers only - call 0420 609 434
Lets keep this thread clean, and for buyers only, cheers
hope these parts can go to a good home.
Pm sent.....
no PM?
Pm'ed
pics of seat? size?
Size... its a Vios III pretty sure they only come in one size... im about 85 kg and its snug on me... you wouldnt want to be any bigger
there are some pics in the build thread. click the link in my sig, its only a few pages long. if not PM me your number and ill sms a few, can find my camera charger atm
All PM's and SMS replied... Just a tip guys, im getting swamped with calls and SMS, if you call, and i dont answer please leave a voice mail with your name and number and i will call you back.
cheeers fellas
my bad you are indeed correct, got mixed up with the zeta III
no worries dude
Hey man, with the ae86 w5x gearbox cross member, is it to suit a custom bell housing (niteparts etc) or an adaptor plate?
Any chance of some photos?
