RWD 16v leads connect from the top
FWD 16v leads connect from the side
both should work on either front or rear wheel drive format
not sure if they are different internally, assuming they are not as both will work anyways
just wondering what the difference is between a fwd distributor and rwd distributor?
(i know I've posted a few of these "stupid" questions, but when it comes to small differences i've got no clue)
dose
so basically aslong as my leads are long enough it should work sweet?
i cant see anything internally being different
yup, as long as your leads are long enough it should work
dose
sweet. thanks heaps mate!
Caps are different as is bigport to smallport. Other than that I think you should be fine.
Number of teeth is different too, so unless swapping ecus they aren't interchangeable between big and small port
ok well that could be a problem because i'm not 100% sure what my motor came out of because i didnt do the 4age conversion. how can i tell?
I think it is 1 for bigport and 4 for smallport?
Smallport dizzy will have 4 wires and bigport is only 3...!
