Bump
PRICE DROP $8200 with rego and rwc!!
Hi I am selling my 1983 Toyota Sprinter 4age conversion all mod plated,
Would make an awesome p plater car lots of fun to drive sticks to the road like anything, the car hasn't done much work since I've had it mainly just driving to work every so often and a bit of driving around town, come pick up a bargain a lot of work for have been done,
Just put on 2 new tyres, new oil Penrite HPR30 oil filter, fuel filter new gearbox and diff oil all filled with Penrite oil's!
Engine:
•Bigport 4age lifted from ae82, rwd converted. Still has redtop covers.
•JDM 96kW ecu & JDM wiring harness. Neat wiring. Check engine light works. No error codes.
•K&N pod filter
•New rwd water piping.
•New rwd water pump.
•New rwd alternator bracket
•Alternator reconditioned last week.
•New silicon radiator hoses.
•New spigot bearing.
•Kaizen Garage extractors.
•Custom 2.5” underdiff exhaust, mandrel bent.Flex pipe, Hi flow CAT, resonator, sports silencer.Nice fit, doesn’t hang down.
Engine was serviced before install so no gremlins. Work included:
•Fresh spark plugs, filter & oil
•New O2 sensor
•TPS calibrated
•TVIS tested.
•EFI loom tested for continuity, no error codes.
•All sensors tested & working right (water temp, cold start, air temp)
•Genuine Toyota gaskets used for assembly
Drivetrain:
•JDM T50 gearbox and bell housing (clutch slave on driver’s side).
•T3 short throw shifter.
•JDM late model T-series diff, disc brakes.
•Cusco 2-way LSD, nice and tight.
•Button clutch by Western Clutch in Sydney. 4-puck, near new.
•Smallport 212mm flywheel, freshly machined & new Toyota flywheel bolts.
•New throwout bearing.
Suspension, brakes & steering:
•Tokico HTS102 dampers all corners. Best you can buy, all adjusters working.
•Cusco cambertops.
•Thick front swaybar, unknown brand, have whiteline rear swaybar needs to be installed.
•AJPS 8kg/mm front springs – fully captive
•Shortened falcon rear springs – fully captive
•Stock ae86 control arms.
•New T3 NRCA’s.
•New ball joints.
•New inner & outer tie rods
•New steering rack boots
•New urethane control arm bushes.
•Urethane trailing arm bushes.
•JDM power steering arms
•JDM vented front disc brakes & JDM calipers
•Rebuilt brake master cylinder
Interior:
•JDM pin stripe dash cluster.
•Full interior, good condition.
•Freshly re-trimmed door cards.
•Good condition parcel tray (blue, not brown).
•AJPS dash mat, black.
•small dished steering wheel.
•T3 spin turn hand brake knob. (drift button)
•Sony head unit but presently 4 " speakers
•Brand new remote mount battery in boot, fully sealed type. TIG’d stainless cradle to secure it.
•Wider accelerator and brake pedals
•Carpet replaced with new Knox auto carpet. Still have original carpet as well.
Uncracked dash
Has 2 black monza bucket seats (non fix back)
Body:
•hole car recently sprayed white (everything beneath guards & bonnet).
•JDM fuel tank.
•New fuel pump (oem replacement).
•New “Toyota” rear tail-light centrepiece.
•JDM doors rust free.
•VGC hatch, rust free with demister.
•All guards well flared.
WHEELS:
15x8 -4 superlights some gutter rash
Comes with 2 25mm bolt on spacers so the wheels fill out the rear guards well (stick slightly out of guards)
THE BAD: rear right guard is cracked because the car rubs if you have 25mm spacers on the back and have people in the back.
Chasing around $8200 call or text me on
Bump
Would it be cheaper if you put standard seats back in?
i dont have the standard seats sorry mate.
Bump need gone ASAP!!!
