Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: ST20V RWD, COP, Rasorback, Remote Oil Filter/Cooler, GTIR intake Quad adapter, SC14 more - QLD
    Mar 2011
    Ali
    Default ST20V RWD, COP, Rasorback, Remote Oil Filter/Cooler, GTIR intake Quad adapter, SC14 more - QLD
    OK, so I have thought long and hard about this, and I have decided to ditch my 4A build for a bigger capacity engine.
    Story is I was piecing this ST20V together, with the plans of full build with low comp forged pistons running the SC14 until I found a decent turbo set up.
    SC14 set up not complete, needs finishing off, top mounting bracket, belt....
    Engine is stock compression ratio, would recommend using a bigger head gasket or low comp pistons if you want to use SC14.
    I have never run this engine with the supercharger.
    Engine - SOLD
    ST20V with Quads
    RWD Format
    Comes with dizzy
    Alloy dizzy blank cap,
    SQ rear bypass with heater pipe fitting,
    SQ front thermostat pipe,
    SQ exhaust side block off plate
    Flywheel,
    AE92 starter,
    Extractor,
    Water pump
    Pullies
    20V Alt with AW11 exhaust side bracket
    Stock Injectors
    Stock FPR
    Sump has turbo drain.
    Coil setup
    SQ COP adapter, spacer and bolts, 4 x 1NZ Coil on plug
    or
    Bosch HEC715 x4 mounted on plate
    Razorback ECU with full loom with every sensor, handset and manual
    - has tune for stock ST20V running 4 coils in waste spark and open quads - tuned in TPS mode
    Mar 2011
    Ali
    Will add pictures up on the weekend.
    If someone wants to make a decent offer on the whole engine in RWD format,ECU with COP set up, with or with out the SC or GTIR parts I would consider it.
    PM offers.
    Mar 2011
    Ali
    Just as an example for shipping on the engine, I had a 220kg engine shipped depot to depot from South Dandenong to Brisbane on a 800Lx800W pallet x700H, for $120 on E-GO Couriers
    I have a ute, and am more then happy to put engine and gearbox on pallet for you and drop off to depot.
    Check out below link for quote price. Extremely good service!
    Mar 2011
    Ali
    All pm's replied to.
    Jun 2012
    Alex
    qld
    if the oil cooler kit dosnt sell i can come pick it up tomorrow bud.
    0416702037
    Mar 2011
    Ali
    Not in any hurry Alex, thanks for the offer, but has dibs.
    Like I say above, this is EOI right now until enough interest is generated.
    Mar 2011
    Ali
    Updated prices with options.
    Mar 2011
    Ali
    $1600 for a ST20V and extractor in RWD format with quads & open trumpets with fully adjustable fuel and ignition ECU and loom?
    I'll even throw in the engine mounts if you need.
    Anyone?
    Mar 2011
    Ali
    Getting close to parting out, get in quick.
    Junior Member slide4fun's Avatar
    Mar 2012
    bronson
    nsw
    port macquarie
    Hi mate,
    Im heaps keen on st20v if your going to part it out for $950.
    Im currently waiting for my tax return but i do have the cash if your keen to get rid of it asap.
    Im also pretty keen on t50 box.
    If you are going to part it out let me know i have cash ready to go..
  1. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
  2. can you run an oil cooler between your remote oil filter
    By kali_man_tan in forum Technical - Questions
    Last Post: 8th June 2007, 12:33 PM
  3. 4age remote oil filter setup
    By ke25 racer in forum Car Parts For Sale
    Last Post: 24th April 2007, 09:35 PM
  4. Remote oil filter for 20v
    By Celica RA45 in forum Technical - Questions
    Last Post: 16th June 2006, 09:02 PM
