Results 1 to 10 of 14
Thread: 4age oil cooler kit
    Dec 2011
    Kerry
    Warradale
    Default 4age oil cooler kit
    hey all,
    whats a good oil cooler kit for 4age? relocated filter or not?
    If you want a reply to this put in a little more effort in your question.
    Use, na or turbo etc
    If na use the stock one from and ae92 / 101 or none. If turbo then the list is endless.
    Dec 2011
    Kerry
    Warradale
    it was a fairly open ended question cause im still not 100% sure on whether im gonna stay n/a or boosted
    sorry man
    Its important to make sure you have good quality fittings and fire sleeve on the kit too... earls fittings are awesome, but will leave your wallet very light and you will want something with a thermostat.
    Ridgehaven
    honestly I think on an naturally aspirated motor an oil-cooler is just as necessary, if not more so than on a turbocharged motor. significantly more time will be spent in the upper limits of the rev range
    save yourself some $$ don't worry about filter relocation if staying N/A. the factory filter position isn't hard to reach and it's not hard to do some sort of heat shield
    ideally I'd be doing this, not all that expensive:
    -quality European/US core (Serck/Earls)
    -Earls braided hose + AN fittings. I don't care what anyone says, Earls fittings are superior
    -GReddy thermostat sandwich plate via Streeter
    Gunner
    For the record earls, is an Australian company.
    Veteran timbo's Avatar
    Tim?
    Wild West
    I did not know this, cheers Gunner!
    I think everyone has covered it, but you can still setup one on the cheap like I did which works perfectly fine. HOWEVER! One of those Grex sandwich plates with a thermostat is the way to go.
    What happens when your oil cooler setup leaks 3:50 for the impatient....
    Aug 2010
    Sutho Shire
    fuck that haha
    Tim?
    Wild West
    Haha jesus. Makes me wonder about my mechanical line in the dash...
  1. Oil cooler kit + oil pumps + fuel rail + ae71 tach dash
    By Sam-Q in forum Car Parts For Sale
    Last Post: 26th July 2012, 11:31 PM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
