Results 1 to 10 of 17
Thread: The defective thread - been defected post the reason here
    Default The defective thread - been defected post the reason here
    Car: Ke70 with a 4agze
    Defect Reason: ie. Too loud, low, awesome etc.
    Fine: $$$$$
    Fixed By: Removing rust / new springs/exhaust etc.
    Time to fix: ie 6 months / cancelled rego / reshelled / parted car etc.
    K Go...
    Car: Rx3 engineered 13b turbo
    Defect Reason: No water in washer bottle
    Fine: Can't remember it was 10 yrs back.
    Fixed By: Filling up with water
    Time To Fix: about a minute...
    Car: Ae82 Corolla
    Defect Reason: Exhaust too loud
    Fine: $300+
    Fixed by: New center muffler
    Time to Fix: 1 week
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Car: 20v KE70
    Defect Reason: Wheels too wide, rear tyres bald, engine conversion (is mod plated in QLD but NSW defect)
    Fine: None
    Fixed By: Ignoring defect and continuing driving
    Time to fix: None?
    Hows that work ,you can't drive in NSW?
    Jacob
    Sunshine Coast
    I went drifting and the defect sheet flew out the window so i ignored it. Still drive in NSW. Haven't been pulled over again though so i don't know haha.
    Adan
    Oxley Park
    Car: GZ20 soarer
    Defect Reason: rear wheels poking out of guards
    Fine: no fine
    Fixed By: getting normal pink slip for rego
    Time to fix: 21 days, but rego was due the next week anyway
    Gone
    Joel
    Picton
    Quote Originally Posted by Jacobxxx View Post
    Car: 20v KE70
    Fine: None
    Time to fix: None?
    Please define to wide officer. They are factory spec.
    Senior Member kyle unwin's Avatar
    Kyle
    Nerang
    Car: Ke70 wagon.
    Defect Reason: Dildo shifter with no shift pattern sticker...
    Fine: $100, and my last point.
    Fixed By: Ignoring defect.
    Time to fix: None.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Car: S13 ca18de
    Defect Reason: to low, wheels to wide from stock, tyres to thin for the wheels.. to much badass he had to put a yellow sticker on the car
    Fine: $300 or close
    Fixed By: raised it cause already had coilovers, threw stock wheels on, got a blueslip done to clear
    Time to fix: 2weeks or something, sold the car after a month
    dose
    Mark
    Car: 4AGE ae71
    Defect Reason: "performance engine swap", aftermarket seats, front brake upgrade, 15" wheels too big, Eyebrow height to low (real ride hieght was 140mm at the lowest point, but eyebrow hieght was lower 50mm and 70mm which apparently requires engineering), coilovers, camber adjustable strut tops. Pretty sure there was other stuff but I can't remember.
    Fine: none
    Fixed by: Cancelling rego, and taking the car off road for 6 months while I got it ready for engineering. I showed the car to the engineer the day of the defect and he reckoned everything would pass fine except I needed a charcoal cannister, I needed a filter on the oil catch can, I needed to tape up the thread on my coilovers so it looks like they won't go lower and I needed to pretend it still and standard engine management. Ended up having issues with the front track width which meant that I had change to some 13's with a more positive offset which meant I couldn't keep the big brakes on. Which also meant that with the eyebrow height set to where I wanted it to be my real ride hieght was 40mm lower and only just legal. The engineering that was only meant to cost a $100 or so according to the policeman ended up costing almost $2000 from the moment I cancelled the rego to the moment I drove it again.
  1. Driving defective car on trade plates - legal?
    By Katatonic in forum General Topics (No Technical Questions)
    Last Post: 13th February 2010, 12:29 AM
  2. 4ac bits.. Vic but will pay post within reason
    By willa in forum Cars or Parts Wanted
    Last Post: 31st January 2010, 09:50 AM
