Results 1 to 10 of 11
Thread: Eoin in Sydney
    Jul 2011
    Eoin
    in my castle
    Default Eoin in Sydney
    Hi my name is Eoin (pronounced Owen for any Australians ect reading)
    Ive been in Sydney 4 years now. I work in central qld on fly in fly out but got a good roster (10 on 4 off) so im back every second weekend.
    so any way i finally have bought a var ive wanted for a long long long time! so heres the story about my ae86
    I bought it on 21 July 2012 from an Australian Guy.
    He had owne the car since 1990, when it was an ADM ae86 with a 4a-c engine I think. He resprayed the car in 90/91 in the original 8a8 and colourcoded the bumpers and grill. He changed the engine to a 4AGE shortly later and changed it again to a 4AGZE from an AE101. Not sure what year he did the supercharged conversion but the car has been in his garage more or less full time since 1995, it’s a very clean shell only getting out 3 or 4 times a year in good weather at a push. The car was engineered and made road legal in 2005 I think with the supercharged engine. Then in 2007 the engineers report was revised to allow for the change from supercharged to turbo. He rolled the clocks back to 00000 2.5 years ago and when I picked up the car it had 1480kms.There is a few little stone chips on it but the paint is in very good condition. It’s an unbelievable build (in my opinion anyway) by a guy who is a true ae86 enthusiast. And lucky for me I was on the hunt for one and made a call to guy who organised for me to meet the previous owner. Let me just say when he took the cover off it I couldn’t believe what I was seeing! Two weeks later I was driving it home smiling from ear to ear! He gave me all the receipts for all the bits, the original drivers manual everything you could ask for really, real nice bloke!
    The only photos i have are taken with my phone so ill get better ones when i come back from work in 10 days. (she's hidden away in a garage under a cover until i get back)
    Engine:
    AE101 4AGZE Bottom End
    4AGE Bigport Head – ported by JB race engines with hardened valve guides & re-shimmed
    TRD Multilayer Steel Head Gasket
    TRD Valve Springs
    TRD Pin Type Sprockets
    ARP Head Stud Kit
    4AGZE Crank Angle Sensor
    Bigport Camshafts
    Bigport Inlet Plenum, ceramic coated
    TVIS plate butterflies removed
    440cc 7MGTE Injectors
    Fuel Rail twin fed & regulator moved to centre
    Tig welded steampipe turbo manifold, ceramic coated
    Stainless 2.5” Mandrel bent exhaust throughout & high flow cat
    TD04 Turbo (ex Subaru WRX)
    APS Cast Dump Pipe, ceramic coated
    Microtech LT10S Injection with X4 Box ignition sequential fire
    Microtech hand controller
    2JZGTE Ignition coil-on-plug
    Sixworks tach amplifier (to make factory tacho work)
    Toda race 3.7kg flywheel
    Sprung clutch with uprated excedy pressureplate
    Greddy Profec B electronic boost controller
    Turbosmart type II BOV
    Mitsubishi Evo 6 intercooler
    Mocal oil cooler
    Mocal oil cooler thermostat
    Remote Z9 oil filter mount
    Aeroquip fittings
    Koyo Radiator
    Battery relocated to the boot
    Gearbox:
    W57 Supra MA
    Dellow bellhousing/kit
    Driveshaft:
    One piece Spicer tube build by Sydney Driveline Services
    Differential:
    Corona MkII F series
    Eaton Truetrac Torsen (Helical) LSD
    Wheels:
    Simmons 3 piece V 16x6.5
    Suspension:
    Koni Sports Kit Springs
    Koni Gold Adjustable Shocks
    Whiteline Blade type adjustable rear swaybay
    Whiteline adjustable panhard rod
    Corona XT130 front lower arms (10mm longer)
    Eurathane bushings throughout all links/arms etc
    Technotoy Tunings traction brackets
    Technotoy Tuning front tri-bar
    Cusco rear strut bar
    Brakes – front:
    Technotoy Tuning big brake kit
    Wilwood dynalight forged callipers
    Brakes – rear:
    Corona Avante Rear dics
    Wilwood Forged Dynalight twin piston rear callipers
    Braided steel brake lines
    Fuel System:
    Bosch 044 in tank pump with Aeroquip one way valve
    Jap fuel tank with swirl pot
    JVC head unit with Bluetooth phone kit
    Immobiliser:
    Black Widow – passive alarming + remote central locking
    Interior:
    84 seats
    Genuine TRD wheel
    VDO gauges
    Greddy boost guage
    I have a dyno sheet sheet here showing the car at 242.4 bhp at 18psi and 210 ish at 12psi.
    Jul 2011
    Eoin
    in my castle
    i cant load pics direct from my laptop...any one who why?
    Jul 2011
    Eoin
    in my castle
    Great base you have there.. should be a fun car to drive.
    Senior Member sheppo's Avatar
    Sep 2011
    Karl
    Hallett Cove
    Looks good mate nicely done!!
    Sep 2011
    Karl
    Hallett Cove
    Jul 2011
    Eoin
    in my castle
ID:	30664Click image for larger version.
    looks a bit difference now...
    15*7.5 -5 meshies and Greddy coilovers
    Veteran drift kid's Avatar
    Glossodia
    Yumm
    ACT
    Compton
    Good lad,deffo improvement!
    Jul 2011
    Eoin
    in my castle
    thanks John, massive improvement! have genuine centre caps for the wheels too and have the mouldings for the doors, wing and quarter to go on next time i'm home! that'll be it finished!
  1. In Need of DIFF in Sydney
    By gottago in forum Cars or Parts Wanted
    Last Post: 14th October 2009, 01:56 PM
  2. SYDNEY May Meet
    By dave2221 in forum Sydney & NSW Events and Discussion
    Last Post: 23rd May 2009, 07:27 PM
  3. New to Sydney
    By Justin Holden in forum Sydney & NSW Events and Discussion
    Last Post: 12th February 2009, 07:39 PM
