Best bang for buck for your application will be a standard 20v rebuild, depending on your budget too
will be very reliable and very cheap and easy to maintain and the standard power out put is more then enough. with an ECU you can already refine the tune..add cams then your pretty much done.
if a stock bigport 16v 4age with 150 000km can drift, i think anything can. Reason why i decided to stay 16v for now instead of upgrading where its not needed yet
4.3 - 4.7 diff ratio helps a lot! and thin tyres too
