Results 1 to 8 of 8
Thread: 4AGZE intake Q's
    Mar 2011
    Ali
    Default 4AGZE intake Q's
    Hi,
    Can I bolt up Quads to a GZE small port or bigport head?
    like is the intake flange bolt pattern on the head/s essentially the same ad the NA version?
    It is right?
    Ali
    Jason
    Gold Coast
    Yep it is. do you have a small port or bigport?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    bigport and smallport are different, seeing as the port size is different
    Mar 2011
    Ali
    Quote Originally Posted by ae86 slide View Post
    I ended up with a AE101 smallport GZE.
    I was considering ST20V ITB with GTiR intake with an adapter, but had serious doubts it would have cleared the clutch master.
    I am now chasing a decent intake for turbo set up.
    Opinions and ideas please.
    Quote Originally Posted by lolwat View Post
    Yeah man, I meant are the GZE intake ports the same as the NA variations
    Adan
    Oxley Park
    a cut and shut smallport intake manifold should do you fine..
    Michael
    Crimebrook 2749
    quads would be cool with turbo setup, help a little with throttle responce, whethere its worth the extra coin or not is another question
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    i dont see the point ? it wouldnt help you benefit with intake your better off getting a custom made plenum
    Mar 2011
    Ali
    I had the GTiR plenum and ST quads, and was toying with the idea, but after close inspection, with the extra added thinkness of the quad adapter it would definitely foul on the clutch master, and thats with a SAMQ gearbox spacer.
  1. 4AGZE Spacer Plate (for rwd intake)
    By Nikkojoe in forum Cars or Parts Wanted
    Last Post: 18th September 2009, 09:03 PM
  2. 4agze Accel cable mount, 4agze ae101 air intake temp sensor
    By Roo. in forum Cars or Parts Wanted
    Last Post: 13th May 2009, 07:00 PM
  3. 4AGZE bits - SC12, throttle, intake, etc
    By Hen is a total nutcase in forum Car Parts For Sale
    Last Post: 5th May 2008, 03:01 PM
  4. 4agze Small Port INTAKE Manifold Wanted
    By Cameron_Datto in forum Cars or Parts Wanted
    Last Post: 3rd January 2008, 03:40 PM
  5. sc12 4agze intake manifold bp cams
    By methodman in forum Car Parts For Sale
    Last Post: 31st October 2007, 08:03 PM
