For those wondering how you wire the relays back to back if you don't have a FOC relay.
Relay 1
Pin 30 to battery source
Pin 85 Straight to an earth
Pin 86 to Starter Relay
Pin 87 To Fuel Pump
Relay 2
Pin 30 straight to battery source
Pin 85 to FP pin on the ECU
Pin 86 Splice into pin 30
Pin 87 To the Fuel Pump
You can use the same power source for both relays. You can also use 1 output wire to the fuel pump joined to each relay on pin 87
