Results 1 to 10 of 14
Thread: Slack in drivetrain
    Tom
    SOR
    Default Slack in drivetrain
    Hey everyone,
    My ae86 has this annoying loose/slack somewhere in the drivetrain e.g when driving along at more than 3000 rpm and suddenly lift off the power I get this clunk like there is a slack/play somewhere in the drivetrain I can feel the slack more in 1-3rd gear less in 4-5th. It only happens on deceleration not acceleration. At first I thought it was the pinion backlash or worn uni joint in the tailshalf they all checked out fine there is not much play in any of them. The bushes in the rear upper and lower arms is also ok. Don't know where to go from here could it be the gearbox? can gearbox have backlash issues?
    Thanks
    Tom
    Veteran timbo's Avatar
    Tim?
    Wild West
    Gearbox?
    Also I have a TRD 2way LSD which is clunkish and chatters if you blip the throttle but apparently 2ways are just noisy.
    Veteran shift_rook's Avatar
    SE Burbs
    box mount? first thought was diff but that's been checked. I wouldn't think gearboxes would have backlash issues like this, though i could be wrong.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Gears can wear over time, if the diff has all been checked I don't see what else it could be. How many km's are on the box?
    Aug 2010
    Geoff
    mt dandenong
    tps, my car does a similar thing
    Veteran Rice86's Avatar
    Richard
    Liverpool
    mine happens from the 2way lsd sometimes, normal i guess.. also happened on an open S diff when i drove it way to hard it use to clunk the one wheel rofl..
    dose
    Tom
    SOR
    Gearbox is in good condition but don't know how many kms it has done but no problem shifting and feels tight etc. but it has been opened at some point by previous owner as it have a TRD close ratio gearset in it. As for LSD I do have a TRD 2way in it maybe that is the cause does 2 way LSD normally behave this way? seems to only happen when I stab the throttle and let go but feels fine accelerating and upshift.
    Tim?
    Wild West
    Yeah, if you slap it/blip it or whatever, a quick tap on the throttle will do this as it locks up the diff. It locks under acceleration and braking.
    Senior Member killabeez_1985's Avatar
    Apr 2010
    Adam
    Mount Gravatt
    My suggestion is maybe universal joints on ur tailshaft.
    Senior Member briigo82's Avatar
    Dec 2010
    Josh
    qld
    Strathpine
    Check your engine mounts, are they munted?
  1. KE70 CS-X with AE71 drivetrain (4ac, T-50, hydraulic clutch) (Melb)
    By cae-086 in forum Cars for Sale (Toyota Only)
    Last Post: 31st October 2012, 04:32 PM
  2. Noisy Drivetrain
    By Tom86 in forum Technical - Questions
    Last Post: 28th May 2010, 11:29 PM
  3. Damaged rear drivetrain
    By Dillon Mac in forum Technical - Questions
    Last Post: 22nd July 2007, 01:14 PM
  4. 20v Power Kills Drivetrain??...
    By Dan_AE86 in forum Technical - Questions
    Last Post: 2nd July 2007, 08:02 PM
  5. How do blow up your drivetrain for dummies.
    By PULSE in forum Offtopic Discussions
    Last Post: 20th August 2005, 01:45 AM
