Results 1 to 6 of 6
Thread: WTB-20v blacktop ecu an maps
    Jul 2012
    Thy
    Ringwood
    Default WTB-20v blacktop ecu an maps
    Hi everyone I'm new to this but was told if I want to run open throttle bodies on my 20v slivertop I will need a blacktop ecu due to the air sensors? Just after a ecu to suit what I want to do.. Got cash waiting for someone that can help me out in eastern suburbs melb... Thanks for looking
    Noooob
    You'll also need to swap the pinouts at the ecu as they are allot different. Not impossible to do, but i'd be asking myself if it is worth the effort.
    Jul 2012
    Thy
    Ringwood
    Would I be better off buying a aftermarket ecu an if so what would be the best one to buy??
    Noooob
    Adaptronic and haltechs are what i'd recommend using... Pm anthony from kaizen if you are keen for an adaptronic.
    Senior Member t-nol's Avatar
    May 2010
    Trent
    So a blacktop and a silver top ecu won't just plug in the same Matt?
    Noooob
    No , different sized connector for the power plug as such, and different spot for a heap of the pins. Most people buy a blacktop loom + ecu to swap them over.
    Silvertop auto is different again from silvertop manual.
    20v Silvertop Manual Pinouts
    20 Silvertop Auto Pinouts
    20v Blacktop Pinouts
    Do you want the open quads for the sound? An enclosed plenum for factory length trumpets will yield a higher HP than running them open. But longer trumpets usually helps with HP, but you need to drop the factory air box
  1. Replies: 7
    Last Post: 17th February 2012, 11:19 AM
  2. Replies: 0
    Last Post: 29th January 2012, 04:29 PM
  3. 20v blacktop ECU
    By OMG866 in forum Car Parts For Sale
    Last Post: 8th October 2011, 02:35 PM
  4. Blacktop 20v ecu
    By damo46 in forum Car Parts For Sale
    Last Post: 14th August 2008, 01:57 PM
  5. Blacktop 20V ECU
    By Hen is a total nutcase in forum Cars or Parts Wanted
    Last Post: 29th February 2008, 09:54 PM
