Results 1 to 10 of 14
Thread: ke70 4age problems
    Jul 2012
    andrew
    Aldinga Beach
    Default ke70 4age problems
    put a fresh 4age into my ke70 wagon now cranks but no spark and fuel pump isnt priming as it used to.
    car was previously running.
    help would be great!
    Check your ecu is powered properly. If it is a big port the pump should prime briefly when you turn the ignition on.
    And check your fuel pump wiring, http://www.ae86drivingclub.com.au/fo...working-wiring
    Jul 2012
    andrew
    Aldinga Beach
    sorry, new to the 4age game, what do i check to see if its powered properly, and its a bigport
    No worries, welcome here too btw...
    If the car was running before you did the engine swap , most likely it'd be the earth wires which bolt to the inlet manifold...
    Trace the loom around the engine, and you should see a clump of 4 or more brown wires which a bolt will go through that is the earth for the entire engine loom. Make sure they are bolted to the inlet manifold.
    Jul 2012
    andrew
    Aldinga Beach
    had that problem when i first did the conversion with the old engine so mad sure i got that right this time, although i had to use the other bolt hole on the inlet manifold as i may have snapped the bolt, that shouldnt make any difference right
    As long as it is a good earth it should be right... Go over all earth connectors and nip them up for peace of mind.
    No fuses blown?
    Ecu power is here...
    Red wire (batt) needs constant power
    and batt+ is ignition switched.
    Also check the earth at the ecu pin E1 is good.. And run a diagnostic check whilst you are at it
    Jul 2012
    andrew
    Aldinga Beach
    ive gone over the fuses and couldnt find any blown one, ill have a good look at it over the weekend. thanks for ya help man, ill let you know how it all goes
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    Get some gritty sand paper and where the earths are on the body sand away the paint as it will conduct alot better than going through the layer of paint, probably wont fix the issue but will run a hell of alot smoother
    Jul 2012
    andrew
    Aldinga Beach
    Cheers man will have a go at that
    Aug 2010
    Geoff
    mt dandenong
    Quote Originally Posted by sleeper_13 View Post
    you can sand away your paint or you can use a star washer
  1. idle problems and wont coast under 3000rpm on 4age in ke70
    By imprezd in forum Technical - Questions
    Last Post: 5th June 2010, 01:37 AM
  2. 4age problems
    By Plain in forum Technical - Questions
    Last Post: 30th October 2009, 06:06 PM
  3. HELP!!! mystery 4AGE problems
    By land yacht in forum Technical - Questions
    Last Post: 20th June 2009, 06:25 PM
  4. 4AGE wiring problems
    By Jazz9 in forum Technical - Questions
    Last Post: 15th April 2007, 03:36 AM
  5. 4AGE fuel problems
    By Jusdrifn 86 in forum General Topics (No Technical Questions)
    Last Post: 27th January 2007, 07:03 PM
