Results 1 to 10 of 15
Thread: tuff diff to suit ae71/ae86. f series, mk2 corona etc
    Oct 2011
    Dion
    wagga wagga
    Default tuff diff to suit ae71/ae86. f series, mk2 corona etc
    im after a diff to suit an ae71 with 300+hp, anything considered and I will pay top dollar, preferable to have all the mounts done or a bolt in package to suit w series gearbox.. jdm t-series would be good, tarago diff, mk2 corona etcI am located in Cootamundra nsw, about an hour from wagga wagga, couriers is preferred, inbox on here or text 0422720872
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    jdm t series will not take 300+hp, smashing teeth on crown and pinion from a 92 rwkw 4age
    The mk2 corona one in that link will tho and Joel has a tail shaft to suit w58
    Michael
    Crimebrook 2749
    pretty bullshit (in a good way) diff and brake setup
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    Weld ae71 sleeves onto r31 diff or hilux, problem solvered
    Oct 2011
    Dion
    wagga wagga
    I didn't think Joel still had the corona diff, if I can get the money before anyone else than I will definitely be getting it, why not I've given the man about 14g already haha
    and the t-series diff, I was going to buy some 26mm billet axles and a 2way diff to suit through weir performance, they seem pretty confident that that set up should handle 350hp
    Oct 2011
    Dion
    wagga wagga
    obviously I would also be getting beefier/different ratio crown and pinion as well, so by the time I'm finished I would have spent 2g+ making it tuff enough.. in which case I may as well buy the f series off Joel haha
    Gone
    Joel
    Picton
    Regardless if it a T diff has aftermarket ratios or not, that motor you now own has smashed 3 x T series centers, that's LSD and crown/pinion.. Not the shafts.
    With 300hp and looking for more, a T diff will cost you
    $200 for a bare diff maybe more
    $400 for cw/p
    $1800 ish for weir billet shafts and Trd LSD
    Then bearings and whatnot to rebuild the rest of it... New pads an rebuild jdm caliper and new rotors.
    Stuff your just under 3K .. And for what, to scrape it off the track when your smash it... 3 k down the drain.
    I have a simple moto. Do it once do it right.
    Yeah it may cost a tad more, but you will only pay it once.
    The F diff and tail shaft is here if you want it man
    Michael
    Crimebrook 2749
    Quote Originally Posted by sleeper_13 View Post
    Have you looked at a hilux diff????
    do you use ke axles???
  1. Replies: 4
    Last Post: 23rd August 2012, 07:52 PM
  2. (SYD) Corona Mk2 F series Diff - $350
    By starni_boy in forum Car Parts For Sale
    Last Post: 31st January 2012, 09:25 PM
  3. F series Diff from mk2 Corona
    By wideslider in forum Cars or Parts Wanted
    Last Post: 12th February 2011, 06:20 PM
  4. Replies: 5
    Last Post: 27th May 2010, 02:38 AM
  5. FS: MK2 Corona F Series Diff and tailshaft & sr20det
    By DR86FT in forum Car Parts For Sale
    Last Post: 5th March 2009, 11:30 PM
