Results 1 to 7 of 7
Thread: JDM AE86 Kouki (25mm axles) T-series disc-disc Kazz LSD 4.3cp handbrake cables
    Tan
    West
    Default JDM AE86 Kouki (25mm axles) T-series disc-disc Kazz LSD 4.3cp handbrake cables
    Price: $1000
    Description: Condition is good, feels tight, no broken/pitted teeths etc.
    * Kouki Late model - 25mm axles
    * Kouki LSD - Looks like Kaaz
    * 4.3 OEM Crown Pinon
    * Complete with handbrake cables
    Contact: PM
    Senior Member fatke's Avatar
    Daniel
    Oakleigh South
    will this diff hold if i run 13b bridgy 230hp?
    CATCH MY DRIFT
    SQ ENGINEERING
    PROTEK
    NCCE ( Naths crazy corolla electrics )
    FATKE & DRFTR86....DOSEING COROLLAS SINCE 2009
    Julian
    Northern suburbs
    does it have the disc brake setup with it? where abouts in VIC you located?
    Rust is a way of life
    Tan
    West
    Daniel: Out of the t-series (6.7") diff, its has the thicker axles so chances are higher to hold. Given torque figures of your bridgey (similar to a 4age?) and they use these diffs in N2 racing with probably around same hp, it will work. Its up to you at the end of the day.
    Diff its complete, calipers, lines, rotors, pads. I'm located 25km west of melb.
    Daniel
    Oakleigh South
    yehhhh need to make a decicion because im going turbo for matsuri
    CATCH MY DRIFT
    SQ ENGINEERING
    PROTEK
    Adam
    South Eastern
    Hi mate,
    can you PM me your best price, I already have a Kouki setup but having one spare is never a bad thing
    Cheers,
    Sep 2010
    Jesse
    Cairns
    Cheapest post to Cairns, FNQ?? Just pm me mate.
  1. Replies: 17
    Last Post: 30th September 2013, 09:26 AM
  2. handbrake cables - T series disc brake diff.
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 15th October 2009, 09:16 PM
  3. T series Disc Brake Diff - Handbrake cables?
    By NIZLAH in forum Technical - Questions
    Last Post: 13th October 2009, 12:40 AM
  4. T series Disc Handbrake cables
    By munki in forum Cars or Parts Wanted
    Last Post: 28th September 2007, 11:52 PM
