Results 1 to 8 of 8
Thread: Broken thermostat housing stud.. FML
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Angry Broken thermostat housing stud.. FML
    Putting all my cooling system back together again today and when I was all done I noticed a small leak coming from the thermostat housing. Tightened the bolt a bit more and then SNAP!!.... and then I got mad..
    Anyway any advice on how to fix this? Or is there anyone out there I can call to come fix it on the Sunshine coast???
    I just want to get the car back on the road again?
    Jake
    Northgate
    Looks like enough left on there to use a stud remover or a pair of vice grips if you don't want to spend some money on a stud remover.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    vice grips or pliers and some muscle, twist that shit out, if its stubborn try heating it with some a flame first. shouldn't be to hard to remove.
    BENT MECHANIX - Garage 20:
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Agreed, a good pair of Vice grips will defiantly get it it out.
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Awesome thanks guys.
    Will give it a try tomorrow and let you know how I go
    Tan
    West
    before u do that, see if u can put 2 nuts over it. Then tighten the inner nut using an open box wrench and it should sit firm against the outter nut. Then go further and hopefully it pull s out the stud.
    say u still lucky, i had one broke flush . Ezy out broke in that as well. Ended up welding to the ezy out and grinding a flat and turning it out.
    Jake
    Northgate
    If none of that works as well I've used a chisel to make a groove and used an impact driver on a stripped allen key bolt.
    2 nuts would be how i'd remove it...
  1. Remote thermostat housing
    By debeli70 in forum Cars or Parts Wanted
    Last Post: 30th July 2010, 03:26 AM
  2. wtb thermostat housing 4age
    By 15LIDE in forum Cars or Parts Wanted
    Last Post: 27th May 2010, 07:11 PM
  3. 4age thermostat housing
    By Go Fish in forum Cars or Parts Wanted
    Last Post: 3rd September 2009, 12:18 AM
  4. thermostat housing off a RWD waterpump
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 23rd February 2009, 06:17 PM
  5. Interior part, Thermostat Housing
    By Dish in forum Cars or Parts Wanted
    Last Post: 5th January 2008, 12:58 PM
