Results 1 to 3 of 3
Thread: 4age, fires speratically but wont run.......Help please
    Senior Member RacerMelb's Avatar
    Jon
    Hahndorf...Beer Central
    Default 4age, fires speratically but wont run.......Help please
    Hey Guys
    I know I am missing something simple, but you know how it is when you have spent 10hours chasing your tail, an outside perspective it always welcome
    http://www.youtube.com/watch?v=CB-ueRtVGfc
    The car is running a carby - electronic dissy via computer set up, not my work but it is what was in the car when I got it.
    The situation, when cranking the spark is erratic, I cant find a common trigger as to what makes it spark or not, very hit and miss and not regular at all.
    I have changed the coil with no change, I have by-passed the ignition switch to ensure that it was not a case of no power on cranking, power to the coil appears consistent, as seen in the clip, it wants to start but the spark comes and goes with out reason.
    Any input appreciated.
    Jon
    Julian
    Northern suburbs
    have you checked that the motor is earthed correctly? I had a similar problem and it ending up being that my earth to the motor and ECU were fried
    Rust is a way of life
    Jon
    Yes the engine has 2 earth wires, and I also ran a jumper lead as well, but it does seem that earthing might be a contributing factor
  1. 4age wont run, replaced throttle body.
    By luke in forum Technical - Questions
    Last Post: 13th February 2011, 06:00 PM
  2. 4AC vacuum diagram/car wont run problem
    By FergusB in forum Technical - Questions
    Last Post: 8th May 2010, 02:30 PM
  3. Vic Fires
    By sonsta in forum Melbourne & Vic Events and Discussion
    Last Post: 17th February 2009, 10:13 PM
  4. 4age wont run on other ecu's
    By mikes86 in forum Technical - Questions
    Last Post: 7th July 2005, 10:23 AM
