Results 1 to 6 of 6
Thread: T50 release bearing noisy!!
    Senior Member bradae85's Avatar
    Nov 2010
    Brad
    Canterbury
    Papanui
    New Zealand
    Default T50 release bearing noisy!!
    Hi have replaced my release bearing in my Hachi as over time it got noisier then started grinding.
    Pulled it out last week and replaced it, the bearing I pulled out was really stuffed with movement in the bearing and when shaken it rattled.
    The new bearing was quiet for a day now when the clutch is engaged it has a slight grinding noise , but comes and goes whilest the pedal is pushed.
    I'm not happy as I don't want to pull the box out again!!!
    Can anyone shed some light on what could be the culprit?
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Spigot bearing also possibly worn out? When does it make the noise?
    Nov 2010
    Brad
    Canterbury
    Papanui
    New Zealand
    Replaced spigot bearing around 4months or 3000kms ago
    Nov 2010
    Brad
    Canterbury
    Papanui
    New Zealand
    It only makes the noise when clutch pedal is pushed. In gear or in neutral.
    West
    They are always a little noisy. Just turn the music up.
    Steve
    Quote Originally Posted by bradae85 View Post
    Could be either spigot, release or gearbox input shaft bearings.
    This happens alot when folks go for stiff clutches, its a fact that cant be corrected, stiff clutch = more forces for the release bearing = wears out quicker or you just live with it.
  1. Hydraulic clutch release bearing for T50 gearbox
    By jimmy19650 in forum Technical - Articles
    Last Post: 20th April 2019, 11:20 PM
  2. need an ae86 release/throwout bearing
    By goose101 in forum Cars or Parts Wanted
    Last Post: 12th April 2012, 08:02 AM
  3. W5x release bearing
    By Pieman in forum Cars or Parts Wanted
    Last Post: 20th May 2010, 07:51 PM
  4. 4age clutch release bearing
    By harvo in forum Car Parts For Sale
    Last Post: 30th April 2009, 01:30 PM
  5. Release bearing Ke70 4 speed?
    By grape_moosha in forum Technical - Questions
    Last Post: 8th March 2008, 11:59 PM
