Page 1 of 25 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 245
Thread: Sam's ke70
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    Talking Sam's ke70, sr20de (autech)
    Hey all
    Im new to the forum and have got hold of a fairly tidy ke70 thats lived a boring life being owned by several old people, now its going to get some proper treatment hopefully i wont slam into a wall anytime soon .. plan to keep it as clean as possible.
    Its a white flat front 5 speed manual 187000km few decent dents in it apparently some drunk wanker walked over it it has a tiny bit of rust starting but nothing major
    its 100% stock atm here it is after pulling off the the grandma spec shit and giving it a good tidy up..
    plans are pretty much to have a good simple suspension setup and engine wise im going for an sr20de autech setup.
    [IMG][/IMG]
    Engine/drivetrain
    sr20de (autech) 90,000km aprox
    modified stock cm to suit sr20 engine mounts
    rebuilt rb30 gearbox ( shifter comes up closer to stock position)
    custom one peice tailshaft
    borgy diff 4.3 ratio (locked) will upgrade eventually
    exedy sr20det hd clutch
    s13 sr20det flywheel
    shortened intake with k&n pod filter
    battery relocated to the boot
    s13 alloy rad
    blank rocker cover with sandblasted finish
    full 2.5" exhaust with hotdog and lukey muffler ( need another muffler bad)
    2L surge tank, carby lift pump and vn commonwhore external pump. all in the boot
    Suspension/ brakes:
    BC gold coilovers (ae86)
    ae86 ps knuckles
    ajps lock spacer
    ajps 40mm rcas
    xt130 lcas
    cusco panhard rod
    whiteline 18mm sway bar adj
    all new super pro bushes
    all new rackends, balljoints, tie rods
    jdm ae86 brakes
    slotted/vented rotors
    interior/exterior
    justjap centered steering wheel
    bride lowmax (copy) driver seat
    lathed up timber dildo gearknob
    vdo water and oil temp gauges
    striped all sound deadening and put carpet back in
    ma61 wheels 14x7 all round atm
    rolled guards and fronts are dodgy cut for castor
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Looks really clean, definately a good base to start from. What are your plans for the build?
    Jul 2012
    Wagga Wagga
    Quote Originally Posted by Jimmee1990 View Post
    Yeah it was a good find my good mate Jake found it while doing his courier run and we went and convinced the old couple to sell it
    plans for the build are to put a sr20de in it with good suspension for a fun simple n.a setup to slide hopefully everything will come together fairly quickly just have to track down all the parts..
    Almost too clean to slide.... But yeah if your mind is made up it it'll be a fun beast.
    Jake
    Northgate
    It is a ke70 so... just don't drift pig it like most ke's make it like one of the clean ke70 drifters.
    Oct 2011
    Dion
    wagga wagga
    what a banged up piece of shit.
    haha just kidding, this is awesome! hope to see it 100% the same body wise, with a nice set of rims and a cranky sr sleeping under the bonnet.
    Oct 2011
    Dion
    wagga wagga
    oh by the way I noticed you're from wagga... I'm from coota, I'm building a dedicated track ksev at the moment, would love to see this in person one day once it's finished!
    cheers, Dion
    Jul 2012
    Wagga Wagga
    Quote Originally Posted by jakel View Post
    Wont be a drift pig in this its too clean and i want to keep it that way for as long as possible
    Jul 2012
    Wagga Wagga
    Quote Originally Posted by dbr11k View Post
    cheers, Dion
    im sure you will see it around as im always going to keep this registered ill have to let you know if im ever going out your way to check out your build.
    Oct 2011
    Dion
    wagga wagga
    yea no worries, hope it all for well for you and doesn't destroy your wallet like mine has done haha
  1. Sam from razerback
    By jimbarno in forum Technical - Questions
    Last Post: 8th September 2009, 02:21 PM
