Results 1 to 6 of 6
Thread: excessive toe
    Mar 2010
    Default excessive toe
    hey guys,
    i just put my front end in and i have an excessive amount of toe in and have run out of adjustment.
    i have a JDM AE86 manual rack, lockspacer, RA60 rackends(have swapped to KE70 to try and rectify),KE70 tierod ends, AE86 powersteering arms and XT130 LCA's.
    my question is
    A. do i need to find shorter tierod's, if so what one's?
    B. i have a fair bit of castor at the moment and was thinking that may be what's causing the toe issue(rethreaded castor rods), thoughts?
    cheers sam
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    I runn a similar setup, I just cut the rack ends shorter
    bursting ovaries since 92'
    Veteran timbo's Avatar
    Tim?
    Wild West
    So toe in? Not this?
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    ^Lol
    Just another Muppet
    Glenn ke_70's Avatar
    Clay
    Barossa!
    buy some ajps tie rod ends.
    or just cut them, might run out of thread length though
    Mar 2010
    all fixed, had waaaaaaaaaaay to much castor backed it off to about 4 degrees and changed my rackends to ke70.
  1. Blacktop 20v excessive fueling - Video Attached
    By Matt in forum Technical - Questions
    Last Post: 29th November 2011, 05:12 PM
  2. Marulan to close down MDTC due to excessive noise .. please vote
    By redsprinter in forum Sydney & NSW Events and Discussion
    Last Post: 11th July 2010, 03:30 PM
  3. excessive play in harmonic balancer/crank
    By Ade_Mc in forum Technical - Questions
    Last Post: 18th September 2009, 12:10 AM
  4. how to heel and toe better
    By Sam_Q in forum Technical - Articles
    Last Post: 16th May 2008, 10:03 PM
  5. 4age-popping excessive flames and fluttering
    By james86 in forum Technical - Questions
    Last Post: 27th September 2007, 09:46 AM
