Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 33
Thread: Engine choice for an AE86
    Dec 2011
    Aaron
    Forrestfield
    Default Engine choice for an AE86
    Hi,
    I have 2x AE86, one has the 4A-GE in it already, the other is a rolling shell. I am stuck with what to put in it.
    I have an S15 SR20DE with all wiring, extractors, clutch, flywheel, RB20 and SR20 boxes but need mounts to suit and a tail-shaft. It makes about 120kW according to Google when new.
    I have a 3T-GTE that has some wiring, a W55 gearbox, needs a turbo, bellhousing, flywheel and clutch (which I have on my TA63 Celica GT-T and will probably upgrade those bits to have hand-me-downs for the Sprinter). Also needs engine mounts to suit. It makes about 120kW stock but most likely easier to get a bit more.
    I also have a 1UZ-FE with VVTi and 5 speed auto out of a 1999 LS400 (complete car still here too). I have a W58 gearbox to convert to manual if needed but I think this is over the top for the car. Will need mounts and tailshaft also. Makes about 215-225kW and is plenty for the car. Currently, I am looking for an XT130 Corona for this engine, as I think that is the best way to use it.
    I do think the 3T-GTE will look more "correct" in the car and I think I need TE72 mounts (??) to simplify the install.
    Any suggestions on what I need? I have obviously over-simplified things but it's a start. I don't really want another 4A-GE and that car will probably get sold off to fund other stuff. I also don't really want to buy yet another engine but if I have missed out something really good, let me know. I think I only need 200kW tops as I may be using it as a fun track car/potential drift but in reality, once it is finished, it will probably only get driven to car shows/barely used.
    Thanks,
    Aaron
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    If money is not an issue, I would go with the 1UZ
    Dec 2011
    Aaron
    Forrestfield
    Quote Originally Posted by maxhag View Post
    It isn't the first issue. I think I want the 1UZ in the XT130, would make a nice 4 seater cruise sort of car, to complement my LS400, plus I can carry more in the Corona. Might be more "practical" in a 4 door that won't see the track as I would prefer to put the W58 in my Celica GT-T and hand down the W55 to the AE86 (I imagine the V8 would make it nose heavy).
    1uz in an ae86 would be insane... primrk started building one with a 3uz but there hasn't been any updates in a while... The mounts where pretty simple too from what i understand, but remote brake booster etc was required.
    What are your plans for the car?
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Coupe of years back , there was a TA22 Celica that had a 1UZ , w58 combo . IT SOUNDED AWESOME !!!!!!!! & WENT LIKE CUT SNAKE !!!
    Had a talk to the guy and he said the box and engine was combo was great , but he was running a T-Series rear end and pit-stops where a case of check the petrol and replace the rear end .
    Go the 1UZ it will be worth in in the end. The biggest drama will be custom build headers and exhaust .
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Moderator Sam-Q's Avatar
    Endeavour Hills
    use the 4ac, if your barely going to use it then why waste a good engine?
    Dec 2011
    Kerry
    Warradale
    personally i definately wouldnt go a 1uz, sr20 would be a better option...
    if anything i would vote for the 3tgte...but im biased on that...oh and i have a crossmember to suit 3t with rack n peanut into an ae86 if you go down that path
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    4g63
    Aug 2010
    Geoff
    mt dandenong
    FA20...........
    s2000 motor (f20c?) or 13b, lightweight and loves to rev, easy power
    Julian
    Northern suburbs
    LS1 ..... runs and hides lol
    Rust is a way of life
  1. headers choice
    By LEVIN86 in forum Technical - Questions
    Last Post: 26th January 2009, 12:37 AM
  2. Colour Choice
    By SON57A in forum General Topics (No Technical Questions)
    Last Post: 23rd May 2008, 06:50 PM
  3. stuck on an engine choice!
    By tetsujin in forum Technical - Questions
    Last Post: 23rd June 2007, 11:46 AM
  4. Colour choice
    By the_sleepa in forum General Topics (No Technical Questions)
    Last Post: 1st July 2005, 07:37 PM
