Results 1 to 10 of 12
Thread: Stupid BT
    Gunner
    Default Stupid BT
    Having some trouble getting this black top running at 100%. At the moment, cold start enrichment is ridiculous, any more than 5% throttle and itll flood and die. Once its warm its ok, plenty of power, till 6700, where it will lay over, and rev cut at 7000.
    Its had a full service, plugs gapped to 0.8, timing is at 10 before (pins bridged) no error codes (even after being run in troubleshoot mode) have changed vvt solenoid, vvt gear, 02, map sensor, checke for vacuum, comp tested (185-190) still need to swap the ecu out.
    Even free revving wont go past 7000.
    I am assuming it is the ecu, and will swap it over in the next few days, but has anyone seen anything similar to this. Guessing its something stupid.
    Cheers,
    Rhys
    Veteran Rice86's Avatar
    Richard
    Liverpool
    just putting this out there
    i have herd 20v are setup to not rev until engine is warmed up from factory, though your one dies so not sure if this is the case
    dose
    Noooob
    For shits n giggles, disconnect the battery, let it run without touching the throttle until it has warmed up.... Then see if it makes a difference.
    Gunner
    Nah this is far worse, from what my ae111 used to do when cold, until op temp, itll run fuck all timing and not trigger vvt.
    Gunner
    Lol for the 7th time?
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    My solution would be to make the worlds first fwd ej20 ae92.
    bursting ovaries since 92'
    Gunner
    Sad thing is itd be easier than the other heap lol.
    Jun 2009
    Blake
    Penrith
    C'mon man don't be like that
    Moderator Sam-Q's Avatar
    Endeavour Hills
    stock ecu? check the capacitors
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    I was under the impression that a BT wont go to the 8k redline until the speed sensor input has been connected.
  1. Stupid Question? Or not?
    By bally in forum Technical - Questions
    Last Post: 10th February 2011, 11:59 PM
  2. Stupid people
    By NathanHann in forum Offtopic Discussions
    Last Post: 8th March 2008, 12:24 AM
  3. stupid copper
    By The_81 in forum Toyotas in the Media
    Last Post: 9th February 2008, 04:55 PM
  4. Stupid S&*t
    By Grommet in forum Offtopic Discussions
    Last Post: 3rd May 2007, 04:45 PM
  5. Stupid people
    By todd in forum General Topics (No Technical Questions)
    Last Post: 14th January 2006, 10:29 PM
