Results 1 to 10 of 11
Thread: microtech ecu problems !
    Jul 2012
    jedd
    nsw
    ocean shores
    Default microtech ecu problems !
    hay i got a microtech ecu an dash and its out of a skyline what do i have to do to get it to work in my 20v ke70 ????
    Jul 2012
    jedd
    nsw
    ocean shores
    and where can i get a loom to fit ?
    Veteran Rice86's Avatar
    Richard
    Liverpool
    what model is the ECU?
    have you tried to contact Microtech for assistance?
    dose
    Member the witzl's Avatar
    Jul 2012
    Karl
    Hills District
    You need to get it "reconfigured" by Microtech to suit the 20V.
    To be honest, Microtech charge a pretty penny for that service (like $400-500), and on top of that they configure it for shitty TPS measurement and lower rpm instead of MAP sensor measurement.
    I'd personally spend a few more dollary-doos and get an Adaptronic, and fit a vacuum collector/vacuum block for the MAP sensor signal so that it works on 100% map sensing (TPS is shit).
    Something like this will fix the vacuum signal to the ECU. Basically you connect a line from the vacuum port at each throttle body, and they collect in this chamber much like a plenum, smoothing out the "pulses" in vacuum signal that make tuning ITBs on map signal difficult.
    Flog the microleb on ebay
    KE70 Turbo 18R-G - Project Skid Car
    Jul 2012
    jedd
    nsw
    ocean shores
    if i get one of them do i just run it from my stock ecu or what do i need to get ??
    Noooob
    Hit up and anthony can supply a full plug / play loom. Mention you are from ae86dc...
    You'll still need a tune done, but i'm sure base maps for a 20v are floating about which will get you to / from the tuner of your choice.
    Adan
    Oxley Park
    Microtechefi.com has all the info to wire up the microtech to a 4age if you decide to stick with it.
    But as said, to send it back to microtech and have it done for a 4age would cost more than its worth to buy another one...look around for a more suitable ecu Id suggest.
    Jul 2012
    Karl
    Hills District
    the adaptronic completely replaces your stock ECU.
    Jul 2012
    jedd
    nsw
    ocean shores
    i got told if i wire up the microtech to my motor and took it to the dyno they would be able to do it there is this true ?
    Adan
    Oxley Park
    no.
    Unless they take it out and send it to microtech for you.
  1. 20c ST with Microtech lt10s rev problems
    By evil86 in forum Technical - Questions
    Last Post: 1st December 2011, 10:33 PM
  2. MicroTech ecu and other bits
    By splinter in forum Car Parts For Sale
    Last Post: 6th October 2010, 02:54 PM
  3. MicroTech ecu
    By bryan3976 in forum Car Parts For Sale
    Last Post: 24th September 2010, 12:50 PM
  4. 20v Tune problems: Microtech LT10s
    By GOT-20V in forum Technical - Questions
    Last Post: 7th July 2010, 09:18 PM
  5. Microtech ECU
    By dvs8tn in forum Car Parts For Sale
    Last Post: 22nd March 2010, 10:30 AM
