Results 1 to 1 of 1
Thread: Help Indentify this Strut
    Aug 2012
    Chipping Norton
    Default Help Indentify this Strut
    HI,
    I need help to indentify this strut.
    I have searched wreckers and found none that match.
    I can rule out XT 130, St141, MX73 and a couple of Celica Models I can't remember.
    The dimensions are as follows:
    Ball Joint/ Steering Arm Bolt centres: 85mm
    Caliper Mount centres 89mm Thread 12 X 1.5mm Mounts may have been modified as all struts I have seen have holes in strut for calipers not threads.
    Stub Axle Large bearing 32mm Small Bearing 19mm Seal 48 mm
    I need to indentify this strut so I can purchase another pair to mod into coil overs.
    I will post images as soon as I find a way to get this forum to accept my pics????
ID:	26540Click image for larger version.
ID:	26541Click image for larger version.
  1. Gas strut between strut top and engine
    By hugh in forum Technical - Questions
    Last Post: 26th August 2009, 11:09 PM
  2. W58 question indentify/shifter position
    By Maxhag in forum Technical - Questions
    Last Post: 15th September 2008, 10:33 PM
  3. 86 strut..
    By metha in forum Cars or Parts Wanted
    Last Post: 1st July 2008, 01:01 AM
  4. can anyone indentify theese control arms??
    By dr1ft-pig in forum Technical - Questions
    Last Post: 30th October 2007, 09:52 AM
