Thinking of selling the power steering in the 86 and putting a manual rack in.
Setup will include everything needed for the conversion:
- All lines/reservoirs
- Brackets/pulleys (Besides crank pulley)
- Belts/tensioners
- Pump
- Rack
- Crossmember bracket
- Steering column
Basically going to supply everything you need to bolt in, fill with fluid and go! Assembly is still in car and needs to be pulled out, so once I have a buyer I will pull it out.
Looking for local pickup only at this stage, too much stuff to post without costing an arm and a leg.
Located in Southern Sydney (10 minutes from cronulla).
Pm me on here for contact.
Not 100% on how much this gear is worth, but I'm thinking $550 for the lot.
Cheers.
