Results 1 to 2 of 2
Thread: DBA Brake Rotors - Street, 4000 & 5000 Series OEM and Slotted!
    Senior Member gslrallysport's Avatar
    Greg
    Default DBA Brake Rotors - Street, 4000 & 5000 Series OEM and Slotted!
    GSL RallySport and Brakes Direct stocks the complete range of Disc Brakes Australia (DBA) disc rotors, from OEM and standard replacement, right through to the 4000 and 5000 series single and two piece high performance brake rotors!
    DBA Street Series
    High quality street level disc brake rotors suitable for normal street driving conditions. Available as a standard Direct OE replacement, T2 slot design or X-GOLD cross-drilled and slotted style!
    DBA Street Heavy Duty
    HD or Heavy-Duty brake rotors is the next level up from Street Series. Hidden within its material composition is DBA's XG150 high carbon alloyed iron and TSP or Thermal Stability Profiling. These rotors are designed for appearance and braking performance!
    DBA 4X4 Survival Series
    For the 4WD enthusiast, the 4X4 Survival series comes in two levels of performance. The entry level T2 slot design, or the more advanced T3 slot design for the series off-road or heavy duty towing applications.
    DBA CLUBSPEC Road & Race
    DBA's most advanced brake rotor on the market. These rotors are designed to perform in extreme road and race applications. Available as a one piece 4000 series T3 or as a light-weight 2 piece 5000 series T3 slot design.
    DBA Kangaroo Paw
    ‘Kangaroo Paw’ is a patented hi-tech disc rotor ventilation system which features a series of 144 diamond and tear drop shaped pillars individually spaced between the rotor faces. This patented design cools the rotor faster, working on the same principal as an air-impeller designed to extract hot air and increases dimensional strength and stability across the disc rotor.
    These advances increase the disc rotor’s efficiency by as much as 20% when compared to a conventional rotor designs and tests are proving that the design is effective for vehicles prone to brake ‘judder’ which is a growing problem around the world.
    Importantly, customers fitting DBA ‘Kangaroo Paw’ rotors will benefit from significantly better braking performance at no extra cost (Patent No. 742353)
    DBA XG150 Alloyed Iron
    DBA Thermal Heat Marking Paint
    DBA Thermal Stability Profiling
    For more information or to purchase any DBA disc rotor, contact the following distributors:
    GSL RallySport
    Ph: 1300 884 836 (within Australia)
    Ph: +617 3188 7534 (International)
    Email: sales@gslrallysport.com
    Web: www.gslrallysport.com
    Address: Unit 5 / 14 Buttonwood Place, Willawong QLD 4110
    Brakes Direct National Offices
    Ph: 1300 724 943 (within Australia)
    Ph: 09 951 5726 (within New Zealand)
    Email: sales@brakesdirect.com.au
    Web: www.brakesdirect.com.au
    Brakes Direct State Branches
    North QLD - Ph: (07) 4422 0303
    South East QLD - Ph: (07) 3177 0806
    NSW - Ph: (02) 9191 9387
    ACT - Ph: (02) 6171 2025
    VIC - Ph: (03) 9938 8221
    TAS - Ph: (03) 6111 0500
    SA - Ph: (08) 7070 1402
    WA - Ph: (08) 6500 0151
    NT - Ph: (08) 7999 7400
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Greg
    DBA's Patented Kangaroo Paw versus traditional straight slot!
  1. DBA Slotted Rotor Pre Christmas Super Sale!
    By gslrallysport in forum GSL Rallysport
    Last Post: 12th December 2012, 01:58 PM
  2. Project Mu Disc Rotors - Street Sports & Club Racing!
    Last Post: 13th August 2012, 07:37 PM
  3. DBA's Massive Slotted Rotor Clearance Sale!
    Last Post: 29th September 2011, 09:10 PM
  4. Replies: 4
    Last Post: 18th March 2011, 05:40 PM
  5. JDM Brake Package - Callipers, New Pads & Slotted Rotors
    By Golberg in forum Car Parts For Sale
    Last Post: 26th September 2008, 10:00 AM
