Results 1 to 5 of 5
Thread: ecu fault codes
    Aug 2010
    Geoff
    mt dandenong
    Default ecu fault codes
    car: ae86
    engine: late model 7 rib bigport
    ecu: suits above- ae92
    fault codes thrown : 5 and 9
    i've checked the ecu diag manual and there is nothing for "5" and "9" is for the speed sensor which is not hooked up, next week i'll run a wire from the dash cluster to the ecu for the speed sensor but what does the speed sensor actually do? as im driving my CEL with randomly come on and off, other people have said when the speed sonsor is not hooked up the light will come on but not go away untill the car has been turned off.
    does it adjust fuel for coasting speeds?
    also has anybody else had a "5" thrown up before? nothing in the book to tell me what 5 would be for.
    I've heard code 5 is the o2 sensor but i've never confirmed it myself.
    The tps adjusts the fuel not so much the speed sensor, other than the annoying light i've never noticed a difference by having it connected or not.. Rumours are the timing advance is retarded without it connected.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Yeah, o2 is code 5, had it not long ago.
    Gunner
    Yeah supposedly without speed sensor connected the computer runs an idle.map.or something.
    I've never noticed much of a difference with it connected or not. But the light being annoying is enough of a reason to connect it
  1. Simple electrical fault?
    By Jkabs in forum Technical - Questions
    Last Post: 9th May 2012, 10:29 PM
  2. Not Holding Tune + Electrical Fault
    By tc-rolla in forum Technical - Questions
    Last Post: 28th October 2009, 09:04 PM
  3. fault codes
    By ae_mule in forum Technical - Questions
    Last Post: 17th February 2009, 10:10 AM
  4. 4AGE ECU codes
    By RolandGTV85 in forum Technical - Questions
    Last Post: 10th September 2008, 10:10 AM
  5. ecu error codes
    By stej in forum Technical - Questions
    Last Post: 5th April 2008, 10:56 AM
