Results 1 to 10 of 13
Thread: 4age dizzy oil ring seals
    May 2010
    Randwick
    Default 4age dizzy oil ring seals
    Hey lads hope this is in the right section, I'm looking for the oil ring seals for a distributor don't think the u ring seal (20mm od,10mm id) can br got from Toyota, basically motor factors or so, tried repco in mascot no luck, anywhere in the eastern suburbs
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    I think AJPS sells them, I bought one from him a while ago.
    Veteran timbo's Avatar
    Tim?
    Wild West
    I have no idea what is going on.
    May 2010
    Randwick
    thanks for the replies lads,just off the phone to ajps there and he doesnt stock the inner 'u seal' ring which is what im mainly after
    Veteran McLEVIN's Avatar
    Nov 2010
    Kbox.com sell dizzy re build kits, might have what you want separately
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    i has one, go on toyo DIY they have a part number, that part number will be fine for any good bearing/seals shop (cbc bearings had 2 for me over night) there ultra heat resistant too
    Senior Member Tally's Avatar
    Tally
    the inner U seal is a non serviceable part from Toyota, the outer seal is available from Toyota for like $6 bucks.
    I got a inner U from CBC bearings, dimensions is about 20mm diameter, 10mm inner diameter and 5mm deep, was basically the smallest they had and fit perfect. cost about $4
    I took the old one with me. Basically you have to take the whole dizzy a part, bit of a pain, but if you are careful and have time and patience its a straight forward job.
    ALWAYS LOOKING FOR KE25 COROLLA PARTS
    May 2010
    Randwick
    thanks for the replies lads got sorted with cbc bearings in kingsgrove orderded today should be here tomorrow.anyway heres the parts numbers for anyone else looking them, inner "u" ring part no: TC12379VI.rubber O-ring. part no: BS217.
    Tally
    Thats the one! surprised didnt have one there...
    have you taken your dizzy apart yet? what shape bit on the bottom end of the shaft is attached?
  1. 4age 16v front oil seals genuine toyota
    By biggo in forum Car Parts For Sale
    Last Post: 25th February 2010, 06:53 PM
  2. Can anyone replace my dizzy O-ring?
    By AE092 in forum Melbourne & Vic Events and Discussion
    Last Post: 7th February 2010, 08:44 PM
  3. Valve Stem Oil Seals
    By Course_Out in forum Technical - Questions
    Last Post: 19th June 2007, 09:05 PM
  4. 4agze cam belt, oil seals
    By deafkid in forum Technical - Questions
    Last Post: 30th April 2007, 09:25 PM
