Results 1 to 10 of 15
Thread: Best horse power mods
    Jun 2012
    david
    queensland
    brisbane
    Default Best horse power mods
    Hi guys....l have a stock 20v silver top....has extractors,black top computer,and pod filters....want to run at 200hp....wat mods would you guys recommend ??thanks heaps. David
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    Personally i would roughly do something like this:
    Rebuild,Aftermarket ecu (and loom if needed), Coil packs, Trumpets, Cams and Cam gears, Pistons, Rods, Crank, Flywheel, Clutch, Head (Porting, polishing, decking and what not) then some bottom end work
    Just another Muppet
    Jun 2012
    david
    queensland
    brisbane
    I did think about full rebuild...but parts and gaskets are so expensive.......have to wait for full rebuild..lol... Thanks
    Adan
    Oxley Park
    I would do this
    sell pod filters
    sell extractors
    sell blacktop ecu
    buy turbo setup
    buy intake plenum
    buy proper ecu
    Lightened flywheel / crank pullies are good bang for buck.
    Spend a bit on the head, thinner head gasket to bump your compression up a little.
    Vaughn
    Sunshine Coast
    David to be honest, Its never really going to be that cheap getting 200hp out of a 4age
    And Adan he would also want to get a thick head gasket if he wanted to go turbo, to bump the compression down so its less likely to detonate
    Just another Muppet
    Moderator Sam-Q's Avatar
    Endeavour Hills
    what intake and ignition system do you have now? On the top of the list should be a new ecu and tune.
    Also genuine parts don't cost much, I sell a full gasket and seal kit for $280
    Jake
    Northgate
    Yeah if you think a gasket kit is expensive then you don't want to know how much it will cost to get 200hp out of a 4age.
    I would say bolt on a turbo would be the easiest way to get to 200hp maybe the cheapest depending on how long you expect the engine to last? But if you want N/A power it will be expensive and need machine/porting done.
    Endeavour Hills
    by the way we already have a thread on this:
    http://www.ae86drivingclub.com.au/fo...read.php/23091
    Quote Originally Posted by Vaughn View Post
    If people are turboing / supercharging stock 2zzge's and the new toyota 86 , i'm sure the silvertop will be right to turbo providing the boost is kept moderately low.
    The knock sensors today are pretty good in knocking back the timing and saving engines.
  1. power up mods for the 20V
    By 4A-G3 in forum Technical - Questions
    Last Post: 31st May 2012, 03:17 AM
  2. MINI HORSE (MINIATURE EQUESTRIAN)
    By Touge205 in forum Car Parts For Sale
    Last Post: 5th August 2008, 02:33 AM
  3. cheapest power mods for 88kw blue top
    By slippry in forum Technical - Questions
    Last Post: 30th December 2007, 10:21 PM
