Results 1 to 10 of 11
Thread: Blacktop MAP sensor
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    Default Blacktop MAP sensor
    Hey I'm converting ae86 to a blacktop I'm missing the map sensor, does anyone know if there is one off another car that can be used as a substitute?
    Cheers.
    Gunner
    Any map sensor off an NA toyota should work, blue sticker, part number starts with 89420
    I should have a 7a map sensor if you get desperate...
    Jun 2011
    Daniel
    Townsville
    How about one off a Rav 4?
    http://www.ebay.com.au/itm/Toyota-se...#ht_500wt_1288
    Cheers.
    Your running an adpatronic right? They have a built in map sensor.
    Just run a vac hose through to the ecu
    Jun 2011
    Daniel
    Townsville
    I did consider that option, the loom I have already supports a map sensor, just thought it would be easier utilizing that.
    Yeah either will work...
    Senior Member JDM-086's Avatar
    Dario
    Melb
    i might actually have a blacktop map sensor... ill check when i get home
    Jun 2011
    Daniel
    Townsville
    How much would part with the sensor for?
    Dario
    Melb
    I believe this is what your after?
    P/N: 89420-12070
    as you can see the wires have been cut... funnily enough i had it running on my 16v
    lol according to toyota its $380..crazy... pm'd a more realistic price
  1. Wanted. 20v blacktop map sensor
    By london67 in forum Cars or Parts Wanted
    Last Post: 20th August 2012, 04:02 PM
  2. MAP Sensor Value
    By Eircamae86 in forum Offtopic Discussions
    Last Post: 3rd April 2009, 04:58 PM
  3. map sensor
    By darkness86 in forum Cars or Parts Wanted
    Last Post: 10th July 2007, 04:58 PM
  4. wtb 4AGE Map sensor and throttle sensor
    By ae86driftstyle in forum Cars or Parts Wanted
    Last Post: 22nd March 2007, 08:35 PM
