no - smallport 4age's also have knock sensors, as do 20Vs i believe.
The only way you will tell what you have is to do compression test and report back with results..... measure the depth from cam covers to the top of piston 1 at TDC (with spark plug removed), and then compare that to the same measurement on a KNOWN smallport 4age
