hey people, got a 20v and just want to run my clutch and flywheel from my 4ac engine, i just need to no how much "mm" is the flywheel so i can order the right size clutch, cheers angelo
If In Doubt, Drift Her Out.
Flywheel from a 4ac is 6 bolt, 4age(16v or 20v) is 8 bolt, so won't bolt up. but dis-regarding that, 4ac should be 200mm, whereas 20v is 212mm clutch plate diam.
Hachiroku since 1994 Originally Posted by LittleRedSpirit When i grow up I wanna be just like Uncle Frak Frak.
Forum Rules
