Results 1 to 10 of 15
Thread: Levin Letter Box Grille Restore!
    Senior Member JDM-086's Avatar
    Dario
    Melb
    Default Levin Letter Box Grille Restore!
    I have a Levin letterbox grille (non foglight type with plastic face)
    As you can see in the pic slightly, the clear is off in some areas and looking somewhat....shit and dull
    I have tried the following:
    -autosol
    -plasticX meguires
    Basically i want to try and restore it to the new CLEAR fresh look again.
    Was wondering if anyone has had any experience/suggestion with this particular task/item?
    I have researched some methods and so far it looks like this is the best way,
    but is still a gamble because most plastics are generally different.
    (does anyone know what type of plastic is actually used for this?)
    -sand it, gradually with finer grit papers (1200/1500/2000/3000)
    -use a fine cutting compound
    -use toothpaste
    -use a plastic polish/wax
    -if still not 100% clear, spray with acrylic clear
    Please don't post comments like "buy a new one" or "get a foglight grille"
    Id like to assess this option first and then I'll make a decision.
    Senior Member Dori_Dori's Avatar
    Andy
    Westside
    I would use car polish.
    If it still doesnt come out what your after, use cutters then use polish again.
    On the cutters dont go too hard.
    Hope that helps.
    Veteran timbo's Avatar
    Tim?
    Wild West
    I tried on mine and failed miserably. Mine was very sun damaged and of course, brittle, so it didn't take long to crack. Yours looks ok, so just be careful with pressure. Sand as you have said then use a plastic polish, I use meguires bike stuff that works well.
    Dario
    Melb
    Thanks for the suggestions
    i shouldve mentioned this
    ill update the first post, but i have tried the following:
    -autosol
    -plasticX meguires
    i have a fine cutting meguires compound for cars which i will try but
    i dont know if any of the above will work as parts of it, as you can see, have peeled so there will always be a difference in levels. where it hasnt peeled, seems fine still and the plastic itself still seems quite good it terms of being damaged or brittle.
    i would be sanding quite lightly and letting most of the weight from my hand with minimal pressure do the work.
    Senior Member davidgarratt's Avatar
    david
    morayfield
    Mate just use headlight restoration kit
    The one to use is hrk01 you can get it @ bursons or coverntry it has the sandpaper, uv protection stuff and Polish.... works a treat.
    Tim?
    Wild West
    That stuff is good but it only masks the problem! I used it on some taillights which worked well, but I know those grills have some many layers on them, which will be better sanded.
    Again, use the plastic polish as a final buff.
    Veteran Nikkojoe's Avatar
    Tom
    Quote Originally Posted by davidgarratt View Post
    This. I've used it on one before and it came out mint. Also used it on my s13, then on actual headlights on my is200. A few different brands are around, all are between $20-50 and have different grades of sand paper, plastic polishes and a UV sealant (much like the stuff that is peeling off the grill right now. I ran out of the kit I bought so I haven't done my current one yet... just go over it a few times with plasticX.
    PlasticX or scratchX work well too, however you need to go over it a few times and buff very hard and will need a touch up every now and again.
    Dario
    Melb
    ill have a look into it.
    concerns are:
    -headlights are a different plastic with different layers and coating
    -kits are designed for oxidization removal as opposed to this case where its an actual peeling layer unlike headlights
    -retaining a completely clear finish. not cloudy
    i've come to the conclusion i will have to sand it if i want any chance of restore. no amount of polishing will compensate for the difference in layers (in theory )
    again unsure of most the above, feel free to interject.
    has anyone actually attempted something like this on a letter box grille with any success???
    (nikkojoe i couldn't work out if you had used it on the grille or just the product on other items ie. headlights)
    Senior Member t-nol's Avatar
    May 2010
    Trent
    The process you listed is correct, but to bite into the plastic, first you will need 600 on the orbital sander (never by hand), then work through to 1200, then 2000 finally.
    You will need a decent plastic cutting polish to get best results from here, car polish is no good, then the finishing buffing polish for plastics.
    We reco these at work.
    Dario
    Melb
    i have an orbital air sander but the finest grit discs i can get are 320 so ill have to do it by hand
    i have plasticX meguires plastic polish and ill probably get a meguires cutting polish too
    is there any need for an acrylic clear coat with this process?
    what kind of things should i avoid that could potentially leave the finish cloudy rather than completely clear?
    shame your not local
  1. levin letter box grill
    By sic86 in forum Car Parts For Sale
    Last Post: 23rd June 2010, 01:23 AM
  2. JDM Levin letter box grill
    By DRFTAE86 in forum Car Parts For Sale
    Last Post: 1st October 2009, 02:10 AM
  3. Levin Letter Box Grill
    By BigWillieStyles in forum Car Parts For Sale
    Last Post: 5th September 2008, 08:06 PM
  4. WTB:jdm levin letter box type grill
    By Jimbo-AE86 in forum Cars or Parts Wanted
    Last Post: 5th February 2007, 10:50 AM
