Results 1 to 7 of 7
Thread: ECUTEK - Launch Control and NO Lift Shifting for the BRZ / GT86
    Default ECUTEK - Launch Control and NO Lift Shifting for the BRZ / GT86
    The guys at Ecutek have developed a couple of cool features for both the Toyota GT86 and Subaru BRZ
    Launch Control
    For those who don't know what this means, it is effectively holding the car at a particular RPM so you can get off the line quickly. Whilst allot of aftermarket ecu's have had this feature for years, the best part of the ecuteck solution is you adjust the RPM via the cruise control stalk to whatever RPM you want on the fly in small RPM increments.
    Here is a youtube demonstration of it in action.
    ECUTECK No Lift Shifting
    No lift shifting is the ability to hold the accelerator flat whilst changing gears. This both minimises the time to change gears and sounds pretty cool in between changes. It is surprisingly smooth and there are other videos where it is as smooth if not smoother than traditional shifting.
    Both of these features have been really well implemented and I'm sure will be popular out on the track.
    Another video here of the flat foot shifting...
    Senior Member t-nol's Avatar
    May 2010
    Trent
    They are some great features to have.
    Veteran Konakid's Avatar
    Henry
    Eastern
    Thats sick
    Veteran johl's Avatar
    Johl
    thats great. almost sounds like anti-lag
    Another cool feature they have introduced is being able to change the ecu map whilst the car is running...
    I'm not sure how useful this would be if you pull into an EPA test area
  1. The Toyota GT86 / BRZ haters thread!
    Last Post: 16th November 2014, 09:43 PM
  2. Forza Horizon Launch
    By EMI GAMER in forum EMI Gamer
    Last Post: 28th October 2012, 01:02 AM
  3. Need For Speed: The Run Launch Event
    Last Post: 15th November 2011, 03:00 PM
  4. Noisy+ not down shifting into 3rds
    By tezza88 in forum Technical - Questions
    Last Post: 2nd August 2010, 08:59 PM
  5. Fixing geabox bushes, for smooth shifting ??
    By Dongaz in forum Technical - Questions
    Last Post: 6th August 2006, 09:53 AM
