Results 1 to 10 of 16
Thread: Castle Hill Performance Centre - Turbo 86
    Default Castle Hill Performance Centre - Turbo 86
    Castle Hill Performance Centre have recently finished development on a drive in / drive away turbo kit for the 86 / BRZ.
    Components
    Haltech Sprint 500 ECU
    Garrett 2871 Turbocharger Running at 5.8PSI
    Front Mounted Intercooler
    Option to retain the Factory Airbox
    Powdercoated Black Piping
    Factory direct port injection controller
    Scavenger Oil Pump
    Dyno Dynamics Results
    Stock Standard: As it rolled off the factory floor - initial dyno results yielded 103kw
    Castle Hill Performance Turbo Charger Kit - 98 RON Fuel : An increase of 60kw at the wheels to a peak power of 163kw 5psi
    Castle Hill Performance Turbo Charger Kit - E85 Fuel : An increase of an impressive 110kw at the wheels to a peak power of 213kw 8psi * Required haltech sports 1000 ecu and GM Flex Fuel Sensor*
    Observations
    The turbo is mounted very low near the gearbox housing, and is considered somewhat bad for most turbo installations. However, with the installation of a scavenger oil pump this issue was quickly overcome and the oil supply is well within tolerances.
    The kit is extremely well put together and a non ethusiast would be forgiven for mistaking it as a factory option. The intercooler looks at home behind the front bar and if painted black would be easily missed as very few modifications were required to make it fit.
    Over all it is a well assembled kit and the only real choice is to run E85 or 98 pump fuel.
    Is E85 Worth the extra 53.2kw?
    53kw at the wheels is definately a power increase that you will notice under your right foot. A few years ago, finding a petrol station that knew what E85 fuel is was near impossible, let alone one that actually supplied it. However, as the use of the fuel is increasing the petrol stations are starting to stock it and it isn't pretty easy to find somewhere to fill up these days.
    Due to the nature of the E85 fuel, the alcohol content is significantly higher and it burns at a much faster rate than that of traditional petrol's. This requires the upgrade of your fuel injectors and the installation of a GM Flex Fuel Sensor as the fuel composition with ethanol changes significantly. As such the tune needs to be adjusted to suit, hence the installation of the Haltech sports 1000 ecu.
    Ultimately you as the driver will need to decide wether you want double the power of a standard 86 or would be happy with only a 50% increase.
    For pictures of the kit please visit http://www.performancegarage.com.au/...o-flex-fuel-86
    or enjoy the video below.
    $6995 supply only with no ecu or tuning soultion,
    $9995 fully installed and tuned.
    Senior Member t-nol's Avatar
    May 2010
    Trent
    Awesome, the E85 tune is sooo much smoother throughout. Now to take the engine apart and build it to suit the turbo application for decent boost.
    ^ Agree totally...
    Castle Hill Performances pricing is $9,995 drive in / drive away.
    Steve
    Quote Originally Posted by Matt View Post
    ^ Agree totally...
    Thats not too bad.
    Is that the eflex tune with haltech 1000 and 3" exhaust.
    Dec 2012
    Bob
    Vic
    So... I heard that not long after this video was taken this car threw a rod through the block.
    Then either the owner or Castle Hill Perf took all of the turbo gear off the car and tried to return it under warranty to the dealer.... lol
    Warranty denied because they had to hack up so much stuff under the engine bay that it was obvious a turbo conversion was done
    Can anybody confirm its the car in this video? Anybody know the owner or anything?
    Steve
    Quote Originally Posted by BentBob View Post
    I wouldn't know what car your referring too but im not surprised by someone throw a rod thru the block.
    Unless your tuning is spot on 100% of the time, 10+ psi, high compression + other unforeseen variables gives little to no room for error especially on stock engines.
    LOL at returned for warranty, kudos for trying thou.
    Bob can you reveal who you heard that from?
    I also will check to see if any engine warranty claims have been submitted with Toyota for a hole in the block.
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    Throwing it out there
    I picked up my car from Windsor Toyota yesterday and the service manager told me about this car and how they denied the warranty after a quick Google search of the plates brought up this video...
    So I would call that confirmed
    Current Cars:
    Thanks robbo... Confirmation , I wonder how the other turbo builds are going...
    After my post questioning the validity of
    the claims, I got a pm saying the owner is still looking for a replacement block and suitable pistons
    it lasted just over a month @ 7psi
    Steve
    Ouch that's not very good at all, i wonder what the issue was, could of been a number of things really.
  1. hill climb/ spint in my ae71 turbo???
    By armc89 in forum Grip and Tarmac Racing Section
    Last Post: 25th November 2011, 09:38 AM
  2. crush the castle
    By breno in forum Offtopic Discussions
    Last Post: 19th November 2009, 09:31 PM
  3. New Performance Centre - Burnie
    By Medwin_3sGTE_AE86 in forum Hobart & TAS Events and Discussion
    Last Post: 8th February 2009, 01:12 PM
