Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: 86 Pistons Pics - Would you use them with a supercharger or turbo?
    Default 86 Pistons Pics - Would you use them with a supercharger or turbo?
    Pistons
    Thanks to http://www.avoturboworld.com for the pictures
    Definately a piston top I'm not used to seeing and it appears to be a pretty strong design... Though how much boost is too much for a FA20 engine to handle?
    Here is a disected view of the piston from the side... Still not much word out there of lunched engines due to boost.
    Senior Member davidgarratt's Avatar
    david
    morayfield
    Cool piston's, I see ART make them they are behind 4age cast pistons and also some HKS cast piston so you know thy are well made they are light also @ 22grams (if that's what the 22g stands for)
    Moderator Frak's Avatar
    Jamie
    ART make a good quality piston, lots of factory race pistons for bikes are made by ART, HRC have used cast ART's for decades and they don't have piston failures.
    Hachiroku since 1994
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    now show me the rods.....
    looks good. ill be planning on turboing or supercharging my 86 in a few years. hopefully i can get away with just thicker head gasket if the rods look as strong as the pistons. i want at least 1 bar FI.....
    Will see what i can find... There is already a company accelerated performance running 15psi on a stock engine..
    Bullet superchargers have verbally indicated the engine is good for more psi than what they are currently running on their car, but they are treading slowly as they want to learn more about the direct injection.
    I love google...
    and
    Dan/Rio
    Randwick
    everything looks good. only issue now is trying to get the compression ratio down from 12.5 to 9.5.....
    those con rods look awesome. press split so each big end cap is matched to each rod. very nice
    Elite rthy's Avatar
    Leo
    Tulla
    Should be interesting,
    here is a 2.0 TDI D4D piston
    the swirl pot seems alot deeper, wonder if a turbo petrol version would need a deeper swirl pot too
    Hopefully in due time subaru will just piff out a turbo model
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    The bowl is a lot larger in those subaru diesel pistons because that's the whole combustion chamber, the head face has very little bowl if at all from memory. I'm sure in time a factory turbo version is inevitable.
  1. Replies: 7
    Last Post: 19th March 2013, 05:46 PM
  2. [WA] Toyota 4AGZE pistons $150 (Ideal for upgrading 4age to be turbo ready)
    By Ghetto-Spec .:bayka:. in forum Car Parts For Sale
    Last Post: 17th September 2012, 07:31 AM
  3. Replies: 3
    Last Post: 27th July 2011, 10:30 PM
  4. Turbo or supercharger?
    By fran1001 in forum Technical - Questions
    Last Post: 11th January 2009, 12:14 PM
  5. GZE/Turbo Rebuild Gear (Pistons/Rods), JDM Cluster
    By 70XIN in forum Car Parts For Sale
    Last Post: 30th May 2008, 11:45 AM
Tags for this Thread
