Pretty sure Beau has a similar setup to what you're talking about.
Check the Hydraulic Handbrake topic in general discussion.
just wondering for those who have done it, i need some pics to see how the mounts have been done, i have a r31 borgwarner diff and i intend to use twin VR rear calipers on each disc, ive rang around fabrication joints and such, but they charge a packet to do it.
so any pics would be great, see if i can go about this myself
if DRIFT PIG aka brendan reads this, how have you mounted the twin s13 rears on, if you have done it yet
cheers Rich.
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
im planning to do this myself...
currently looking at either twin s13 or twin commodore calipers...
got a fair idea of how ill be doing it...but wont know til i get around with playing around with calipers/disks and mounting methods...
so keen to see wat goes in this...
MY AE86 BUILD
will check out the hydro handbrake section, ive seen a pic of beaus setup but it was on the old forum, any others
SQ ENGINEERING
NCCE
ive got a twin rear setup forsale if u want it... its off steroidchickens F series.. VR and R31 ... comes with brackets calpiers and rotors.
im going to be changing it to twin R32 skyline .. eventually once a few other bits are completed..
heres a tip once u have made the bracket.. mount up the disc and calipers .. hook up the brake lines, get somone to apply the pedal.. and wallah! instant perfect alignment.. while holding the pedal.. throw down some tack welds.. perfect.
This is a sketch for twin R33 calipers onto (drum) F series diff. Gives an idea how it can be done.
Also to keep everything good with the bearings and axles we were planning on milling a few mm off the ends of the diff body, so we could use a thicker, stronger mount.
nice hen!.. a mate is giving me AUto CAD and the manuals.. so hopefully i can work my way through it and come up with a drawing like that... i think R32 and 33 are same caliper on the rear.. or is that 32 GTR and 33 gtst?
NFI. I drew that up at least a year ago when sitting with the bits in front of me (for Rallystanzas car).
From what I've heard, Autocad = gay. I use Solidworks at work, and it's very easy to get started, but you can also do anything with it too.
we welded the mounts onto my diff housing just used flat steel clamped the calipers onto the disc centred them and welded em on works mint
AE86 THE BEST
Any pics Fast Eddie?
