Results 1 to 10 of 11
Thread: charging issue with my drift car running 15.5volts
    Jul 2009
    shaun
    nsw
    port macquarie
    Default charging issue with my drift car running 15.5volts
    Hi guys
    ive got an ae86 drift car with an sr20det in it i noticed the other day that when the car is running it was producing 15.5volts so thought ok alternator was in need of replacing so i got a second hand one fitted it same deal. so i thought unlucky got a dud one. borrowed a mates one off his car that im 100% works fitted it up and still dose the same thing??????
    now i was told that i need to have a battery light in there for it to work right??? is this correct and if so how do i hook it up and to which wire off the alternator dose it go to??? thanks for the help
    Generally yes you need the charge light hooked up.
    Member the witzl's Avatar
    Jul 2012
    Karl
    Hills District
    Yep - hook up the charge light... otherwise the regulator isnt getting a voltage reference and will give full output.
    KE70 Turbo 18R-G - Project Skid Car
    Jul 2009
    shaun
    nsw
    port macquarie
    Quote Originally Posted by the witzl View Post
    yeah i get i need it but how do i hook one up as i have a full alloy dash in the car do i just use a pilot light and put it in line with one of the alternator wires?????
    sorry for the dumb arse question but only have a week to fix it before next round
    Run a new light somewhere.... 12v ignition to one side and the alternator pin is effectively the earth.
    Jul 2012
    Karl
    Hills District
    what Matt said.
    Ign 12V+ to one side of the light, and the other side (earth) goes to the charge light pin on the alternator.
    When the alternator isnt working, the charge light pin pulls to earth and the charge light illuminates on your dash.
    Senior Member pt_y2k's Avatar
    Paul
    Nissan alts also have a "S" terminal,its a battery voltage sense wire,ya sure tis is connected? in the small 2pin plug on the alt the heavy wire(normally white) should have 12v at it when not connected to the alternator...
    Jul 2012
    Karl
    Hills District
    Yep, if the nissan alternators have that "S" pin, it MUST be wired to battery positive terminal via a fuse. If not connected, this could also explain the high output voltage.
    Jul 2009
    shaun
    nsw
    port macquarie
    Got it sorted guys thanks heaps turns out it was wired backwards from old owner. Now it charging at 14.3 volts. Only issue now battery light is always on???? Do I need a resistor or something in line??? Thanks again guys
    Adan
    Oxley Park
    Is it an LED or normal globe?
    If LED you may need to run a resistor..
  1. car running too cold what the hell
    By slider4life in forum Technical - Questions
    Last Post: 17th June 2010, 10:01 PM
  2. 4K-C idle and running issue.
    By AE86 Spoontah in forum Technical - Questions
    Last Post: 14th June 2010, 09:05 PM
  3. what tyre is your car running?
    By Rob in forum Technical - Questions
    Last Post: 27th September 2008, 08:36 AM
  4. get my car running sale
    By fozz in forum Car Parts For Sale
    Last Post: 4th August 2008, 04:26 PM
  5. get my car running!
    By jono86 in forum Car Parts For Sale
    Last Post: 21st January 2008, 11:08 PM
