Results 1 to 10 of 10
Thread: motor dieing on bumps
    Aug 2010
    Sutho Shire
    Default motor dieing on bumps
    car-ae86
    motor-4age bigport with rwd manifold
    problem-whilst driving tonight my 86 started to drop in revs for a breif second when ever i went over a bump on the road,at a latter stage when on a bad
    section of road it made the motor stall,headlights,music etc was still on,started fine off i went,this then happened once more before i made it home.I checked that various plugs and spark plug leads were on properly,battery terminals are tight,when driving on a smooth road it hauls ass like before,just bumps gives it issues,no warning lights or anything came on on the dash so alternator should be fine?so got me thinking a loose or worn out plug,sensor,
    or earth,could someone point me to which ones could possibly cause this bullshit,stingin to drivveeee (colour and location etc would be awesome)
    Most common is the wiring around the dizzy plug... always wears / breaks around that.
    Does it start / drive now?
    Aug 2010
    Sutho Shire
    yer starts fine and drives fine till i hit a bump,by dizzy plug do you mean the big round yellow plug?
    Yeah that is the one, just unplug it and inspect the condition of the wiring on both the dizzy itself and the loom... Normally on the loom the black wire is frayed / busted.
    So it is 100% reproducable each time the engine cutting out when you hit a bump??? Wriggle the connector on the firewall and also the one around the coil as well whilst it is running, it should cut out too.
    Aug 2010
    Sutho Shire
    thanks,ill check that plug,wires and wiggle them to see if it cuts out,thanks matt,ill post up what happens
    It shouldn't be hard to find / resolve... see how you go and if you get stuck I drive past your way a fair bit so it shouldn't be much to drop in and spend a couple of minutes looking over it.
    Aug 2010
    Sutho Shire
    upon inspection just now i saw my alternator is not spinning,possibly could of been dieing?
    May 2010
    Randwick
    Check the block connectors at the injectors sometimes they become brittle and crack causing a loose connection.
    Alternator not spinning is a bad thing.... measure your battery voltage and it should be 14v or there abouts, if it isn't a half hour drive or so will kill your battery. Also check that your batt terminals are clean and nice and tight cos hitting a bump and it cutting out the alternator should have enough to keep the car running if the earths are all in check.
    Aug 2010
    Sutho Shire
    All fixed guys, found a chassis earth had lost its nut cause bad earthing, cleaned it up put a new nut on, life is sweet again ,thanks for your help matt and others, i also contact cleanerd all plugs as they were gross
  1. Carb 4age - engine dieing
    By Deeken in forum Technical - Questions
    Last Post: 23rd October 2011, 06:18 PM
  2. ae86 trueno headlights dieing
    By ae86 in forum Technical - Questions
    Last Post: 17th June 2010, 02:01 AM
  3. Replies: 9
    Last Post: 2nd September 2009, 08:46 PM
  4. Brake Lights Flash On Bumps
    By Will(SPA50) in forum Technical - Questions
    Last Post: 22nd January 2008, 11:06 PM
