Results 1 to 4 of 4
Thread: 20 valve Blacktop ECU Grounding Points
    Mar 2011
    Ced
    Rowville
    Default 20 valve Blacktop ECU Grounding Points
    Car: AE86
    Engine: 20 valve blacktop 4AGE
    20 valve blacktop engine exhibits extrodinarily high idle at 2000rpm. Something was telling the ECU to fully open the ISCV valve. Trawled the forums to find this post: http://www.ae86drivingclub.com.au/fo...-20V-High-Idle
    The thread says that certain unused load inputs must be grounded, such as the AC. After grounding the AC1 & ACT pins, the idle has dropped to 1500. Leaving it till warm, the ISCV will pull the idle down to 1100. However, whenever driving, the idle goes back up to 1500.
    Besides the AC1 & ACT terminals on a stock blacktop ecu, what other unused pins should be grounded?
    Member the witzl's Avatar
    Jul 2012
    Karl
    Hills District
    have you wired up the speed signal input (normally SPD or something similar)? Perhaps the ECU is out of whack no knowing if the car is moving or not?
    KE70 Turbo 18R-G - Project Skid Car
    I haven't confirmed the video is correct, but found this on you tube a while back and was planning on verifying it, but never got around to it.....
    However it might be useful.
    Mar 2011
    Ced
    Rowville
    Nice vid. Used it to double check my plumbing, and it's all the same.
    Putting the car into diagnostic mode drops the idle back to baseline, around 900, which means that the iscv control is definitely working. Which leads me to believe something else telling the ecu to idle up.
  1. AE71 Blacktop 20 valve project QLD
    By stixy in forum Cars for Sale (Toyota Only)
    Last Post: 23rd March 2011, 06:57 PM
  2. 20 Valve Blacktop to RWD?
    By mr.smirfy in forum Technical - Questions
    Last Post: 26th February 2009, 09:40 AM
  3. 20 valve blacktop conversion
    By ap7 in forum Cars or Parts Wanted
    Last Post: 12th July 2008, 10:57 PM
  4. dli systems for 20 valve blacktop
    By darkness86 in forum Cars or Parts Wanted
    Last Post: 3rd June 2007, 11:55 AM
