Results 1 to 10 of 14
Thread: 20v silvertop AFM WANTED, ALSO a/c bracket with tensioner!
    Aug 2012
    sam
    vic
    oakleigh
    Default 20v silvertop AFM WANTED, ALSO a/c bracket with tensioner!
    hey guys,
    after a silvertop AFM cheap, only need it to get engine running and tuned
    also a air con bracket with tensioner to be able to use my power steering pump
    thanks, Sam
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have an air con bracket modified for rwd use however I don't think that would work with your power steer bracket
    Aug 2012
    sam
    vic
    oakleigh
    Does it interfere with the p/s bracket? I only need to use the tensioner on it haha how is it modified? I need to come get a couple more bits from you soon too
  • #4
    Endeavour Hills
    I don't know about the P/s bracket as I can't remember how it fits, got a pic? It's modified to clear the rwd engine mount
  • #5
    Aug 2012
    sam
    vic
    oakleigh
    ah i see...it may fit then as the p/s bracket mounts above the a/c. how much do you want for it? and still has the tensioner at the bottom?
    ill get a photo tonight but im pretty confident it'll clear the p/s
  • #6
    Endeavour Hills
    I only want $30 with the spacers which you probably dont' need, I will take a photo of it for you
  • #7
    Aug 2012
    sam
    vic
    oakleigh
    ok awesome thanks
  • #8
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    I've got an AFM to suit silver top. Comes with pod filter adapter
    Pm me if interested.
    Vener
  • #9
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I think I have a 20v aircon bracket, still has the pump on it too.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  • #10
    Endeavour Hills
    As promised:
    One foot was made thinner to slide under the rwd engine mount, the other to make it level. I can remake a spacer if needed. This suited a 20V air con pump, 16V is different
  • Page 1 of 2 1 2 LastLast
    1. Wanted ASAP 20V Silvertop Auto ECU and AFM
      By ONCE-NA in forum Cars or Parts Wanted
      Last Post: 14th March 2012, 08:41 PM
    2. 20V loom, AFM and ECU wanted
      By terryo in forum Cars or Parts Wanted
      Last Post: 23rd February 2012, 12:39 PM
    3. FS. 20v silvertop, RWD alternator bracket and more
      By OMG866 in forum Car Parts For Sale
      Last Post: 25th July 2011, 12:36 PM
    4. 20V alternator bracket and tensioner
      By Sam-Q in forum Cars or Parts Wanted
      Last Post: 5th February 2011, 08:39 PM
    5. RWD? Alternator tensioner bracket
      By NIZLAH in forum Cars or Parts Wanted
      Last Post: 4th August 2009, 05:28 PM
